Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
WATER DISPENSER INOPERATIVE - Whirlpool ED5FHEXMQ Side by Side Refrigerator
  • Whirlpool Master
  • 4,655 Answers
When the water dispenser control does not work it is most likely the dual water control valve on the rear of your refrigerator that controls the dispenser side that has malfunctioned. Part number 4389177 Most times the solenoid for that side has failed. Thanks, Sea Breeze
Posted on Sep 25, 2009
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: Icemaker / water dispenser develops
You stated that your unit is developing heavy frost where the water dispenser/ ice maker is makeing your unit unable to produce ice. One of the first things that you should do is remove the ice maker and then remove the rear panel on the inside back wall of your freezer. This would then give you access to the evaporator coil in the unit. If when you remove this panel you see ANY ice build up on the coil itself this is considered a defrost issue. The defrost issue is due to either the defrost thermostat, the defrost heater, or the defrost timer or in some units instead of a defrost timer they have an adaptive control board. The defrost thermostat is usually located on one of the sides of the evaporator and is a small disc like object with two wires that go to it. You can assure if the thermostat is working properly by conducting a continuity test on the thermostat itself using a mulitmeter. 85 percent of the time in the units I fix the thermostat is the main issue. The same continuity test can be performed on the defrost heater as well if you do find that you do have continuity in the thermostat. This test would also tell you if the defrost heater were working properly as well. If you find that both the defrost heater and thermostat are working properly or that you have no ice build up on the evaporator coil when you remove the rear panel message me back for further diagnosis. Note if you do find any ice build up on the coil this also has to be defrosted my personal preference to defrost is using a hair dryer but I have also seen people use hot water to defrost the coil although it tends to be a bit more messy using water. I await your reply if you have any further questions. Thanks
Rick
Posted on Aug 31, 2011
Replaced water dispenser still not moving or getting water
sad but we can not look it up as were not given make or model
Mar 26, 2015 | Refrigerators
My water dispenser in my GE Adora stainless side by side refrigerator is not working
Water dispenser doesn't work
  1. Dispenser control board
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
  1. Water tube in door is frozen
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Feb 22, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
GE profile refrigerator ice maker not working
Ice dispenser doesn't work
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
  1. Dispenser switch
  1. Door switch
  1. Dispenser switch
  1. Water filter
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Why is my Water dispenser not working?
  1. Dispenser switch
  1. Water filter
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Refrigerators
We have an Electrolux S/S side by side w/Ice&water though the freezer door. The water flow through the door has been inoperative for several months but the ice maker continued to work fine. Water...
check and see if there is a built in filter pack inside the back of the fridge or it could possibly be that one of the lines has froze internally and or the open close valve at the water inlet inside has worn out
Jan 18, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Inoperative Culligan RO water monitor (LEDs don't light up)
Dave,
If you have concern about the quality of water being produced by your RO system, I would recommend using a handheld or in-line TDS meter. Instead of a red or green LED, these meters will give you a reading of TDS (total dissolved solids) in parts per million (PPM). With either of these meters you are taking a reading from the feed water to the system as well as from the product water, you then can calculate the percentage of solids being rejected by the RO system (using the simple equation listed below). This way you will know exactly how well the RO system is working and when the membrane needs to be replaced. I have included links below to our selection of handheld and in-line TDS meters as well as an instructional video that explains how to use a handheld TDS meter.
Here is a helpful link that includes the formula for calculating percent rejection.
http://www.freshwatersystems.com/t-measuretds.aspx
Handheld - http://www.freshwatersystems.com/c-253-handheld-meters.aspx
In-line - http://www.freshwatersystems.com/c-255-in-line-monitors.aspx
Video - http://www.freshwatersystems.com/t-videos.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Jul 19, 2009 | Culligan Under Sink Water Filter
Fridge/freezer inoperative
does your fan work in the back of the unit. Either that or it could have been your compressor
Dec 23, 2008 | GE GSS22JF Side by Side Refrigerator
GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
266 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
