Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
I can not put the belt on correctly - Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
  • Chuck
    Chuck May 11, 2010
    You are trying to put a belt on a 46" Dozer blade as it says at the top of this "problem" ??
  • 472 Answers
IF YOU WILL SEND ME THE MODEL AND SER# I WILL HELP YOU WITH THAT
Posted on Oct 08, 2009
How to install belt
Carefully thread through loops of jeans. Make sure buckle is facing outwards. Use same philosophy for belt on mower.
With engine off, thread belt around drive and driven sprockets. Excess slack will go around idlers that put the belt in the correct alignment with the sprockets. Last step is to put the engage lever in the MOWER OFF position and fit the belt to the correct side of the roller.
Mar 03, 2015 | Garden
I PUT 2 NEW BELTS ON A 10.5HP MASTERCRAFT SNOW BLOWER (AUGER BELTS) AN THEY WON'TSTAY ON. TERRY
Are you sure that you have routed the belt(s) correctly? make sure it goes around the tensioner and pullies correctly. Also make sure that you have the correct size belt. Good luck...
Oct 29, 2013 | Garden
04 sierra 3500 8.1 liter. Belt is loose after changing alternator.
Make sure you belt routing is correct. Then check your belt if it is original then you are fine but if you replaced it as well, double check you got the correct length belt. lastly check the size of the pulley. If its smaller then you need to get the correct pulley put on or switch to a smaller belt. My money is on your belt routing being incorrect
Aug 08, 2013 | Chevrolet Cavalier Cars & Trucks
I need to know the correct belt for my Eurecka Boss 4870 Refurbished. Every time i put the belt on it brakes.
the correct belt for this machine comes in a package. It should be Eureka Style R belt. (61110-A)
Pic attached.
This is the correct belt. Anything else will just snap right away.
Good luck.
Nov 13, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do you put the belt on on my dryer ? every time I put it on it has alot of slack
your not getting it onto the idler pulley,or your not routing the belt correctly,when it goes over the idler pulley correctly there will be a lot of belt tension then as you need to force the idler over to get the belt over it
May 27, 2010 | Maytag MDE308DAYW Electric Dryer
How do you put a serpentine belt on
Rotate the tensioner till belt is loose. Move belt off of the ideler pulley. Replace and use guide found under hood for correct belt routing
May 19, 2010 | 2001 Oldsmobile Aurora
Belt keeps slipping off need to check the correct belt number and what can i do
What does it slip off of, the brush or the motor? Are you sure that it is in correctly, as there are usually 2 ways of putting the belt on. If put on correctly, it should not contact any part of the vacuum except the motor shaft and the brush. Also check check there is not a buildup of hair, etc. where the belt goes around the brush. I would try turning the brush by hand and see if anything is interfering with the path of the belt. There is always a chance that some part of your vacuum has broken or malfunctioned and is touching the belt and making it come off. Also, make sure that the brush is correctly installed.
The tension on the belt should be pretty high so that it is hard to pull out of place. If not, you could have the wrong belt. I believe that this takes a type "U" belt if that is any help. Hope this helps and good luck!
Mar 15, 2010 | Eureka Whirlwind LiteSpeed 5843 Upright...
Diagram of pullies and belts on 86 toyota mr2
If you are talking the a/c pulley and alternator pulley, I am pretty sure the belts are different sizes (different number of ribs in the belt). So, you can just look carefully at the ribs and put the right belt on the right pully. from memory, the A/C belt goes on first and all the pullies towards the front of the car are used for that belt. The Alternator belt goes on next, and all the pullies from the crank shaft toward the back of the car (from the crank pulley) go to that. I could have those reversed, but the ribs on the belt will show you for sure. have fun!
Mar 06, 2010 | 1986 Toyota MR2
Timing belt tracking is bad on a 1999 Daewoo Lanos
  • was washer put back on the crank correctly? Is there spacers or gromits that hold the timming cover on? Sometime I run car before I put all excesserys back on just to see that problem...
Jul 21, 2009 | 1999 Daewoo Lanos
I am installing a new belt but the pulley that mounts to the ground i found was not attached and i am not posotive of its correct spot i need a diagram
The idler pulley goes in front of motor shaft. There is two slits in sheet metal where it slides in. after pulley is on. put the belt around drum and pinch belt together. put belt under idler wheel then put end on motor shaft. You can push up on idler pulley to get around motor.Make sure grooved side of belt is wrapped around drum. Good Luck!!
Apr 24, 2009 | Dryers
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
109 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
