Question about Samsung Digimax S630 Digital Camera
My samsung s630 just one day stopped working. The lens.....
The one day i went to turn it on after putting new batteries in it then all of a sudden i turn it off and the lens wont go back in and it's basically fully zoomed in when i take a picture. And no matter what i do the lense wont shut and it wont unzoom when i try too. And when i do it shuts off. Can anyone help me?.....
jackboy
  • 2985 Answers
SOURCE: I am have Samsung Digimax S600
Well all the time these item [didgi cams and small electronics of all sort do seem to have a high fail rate. But as I said less than a year - take it back
Posted on May 25, 2007
Gwenivie
  • 39 Answers
SOURCE: S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Posted on Jan 11, 2008
  • 3 Answers
SOURCE: samsung S630 junk
I am Judy Malone in Tenn and I had my camera all in box and ready to mail back to place listed on camera box. I had worked on camera for last few days and to no avail. I got the notice via email today and the usual steps that I've read before.
To take batteries out, insert again. And to hold the ON button to keep camera powered. Then press Center button OK and press RIGHT 3 times to Setup2...
Well, I could not get my camera to co-operate past the Press Right 3 times to setup 2. Only the usual screen with a few of the icons showing my battery had power. It would not do anything past this.
Well, I got mad...(smile) and figured something had to be wrong as it kept showing a 32 for picts and I knew I had taken 414 at least on my Lexar 512 MB (SD).
I thought something must not be aleigned properly..some pins inside or somthing, so I GENTLE tapped the camera against my kitchen table... First one side, then the other..and GUESS WHAT. My camera came to life and has been working fine since. I HOPE this is a permanent fix...as I love the camera and have said so.
So, for what it's worth...try this if everything else seems to fail...but please do it gently. And start from the beginning.
Take batteries out, then reinsert...and GOOD LUCK.
I will post again...and let you know if this continues to work.
I am amazed.
judy in Tenn
Posted on Feb 19, 2008
SOURCE: Lens
I had this problem with my daughter's D860, so the fix may help for this also.
As you know, externally the lens has two parts; the long barrel with glass lens at the front and the bottom part that rotates to move the long barrel in and out.
All I did was keep twisting the bottom part (that rotates) clockwise and anti-clockwise whilst turning the camera off and on. It may take quite a few attempts, but in my case it finally worked. So far anyway! who can say if it'll happen again.
Warning! Obviously take care how much pressure you put into twisting the rotating part of the lens. You wouldn't want to break it!!
Posted on Mar 08, 2009
  • 11967 Answers
SOURCE: Samsung L313 camera - lense is not retracting when off &...
You could return it (recommended) or try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 07, 2010
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Samsung Model S630 Lens will not retract into camera.
Remove the battery and insert new battery and check if it is working .
If it is not working then you gently tap on the sides of camera this will work .
Oct 20, 2008 | Cameras
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
CAMERA LENS STUCK OUT
chech and make sure that your lens isnt bent to the side, because i had the same problem and as soon as i bent my lens back it turned on and worked like new
Aug 26, 2008 | Samsung S630 Digital Camera
Camera lens stuck
Push lens assembly back in with your thumbs until you hear a click.
Aug 18, 2008 | Samsung S630 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Feb 17, 2008 | Samsung S630 Digital Camera
Camera will not take pictures
Try a different brand of batteries. I found that my Samsung S85 went completely bonkers with some (unbranded) Nimh batteries I had. I switched to Engergizers and it's been fine ever since.
Also go into the camera settings and see if you have an option for which type of battery you are using (Nimh vs Alkaline).
Feb 17, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
49 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
