Question about Texas Instruments TI-84 Plus Calculator
My TI-84 Plus SE is stuck on the "Garbage Collection" screen. Is there any way to fix this?
  • Texas Instru... Master
  • 8,073 Answers
Press [2nd][QUIT]. If that does not work, remove the main batteries. Wait a little while, then insert them back again. It will attempt to continue garbage collection but will say Ram cleared. Clear the screen ant start using calculator.
Hope it helps.
Posted on Sep 25, 2009
Is it possible to change the faceplate of the TI-84 Plus calculator?
Yes, you can change the faceplate of the TI 84PLUS Silver Edition only, not the TI 84 Plus. Face plates are available for purchase at the TI online store.When you go the online store, select the country, then the calculator model. You will find them under accessories for the TI 84 Plus SE.
Aug 15, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 calculator says "Garbage Collecting" and won't work, how should I reset it?
Found at www.epsstore.ti.com
What can be done if a TI-83 Plus family or TI-84 Plus family calculator displays Garbage Collecting... for more than 20 minutes?
The garbage collection allows the cleanup of unused archive memory. It deletes unarchived variables from the user data archive and it rearranges the remaining variables into consecutive blocks. When a variable is unarchived, the Archive free memory amount increases immediately, but the space is not actually available until after the next garbage collection.
If garbage collecting is more than 20 minutes, the calculator has possibly locked up and will need to be reset.
The reset procedure will delete all the items that are in the memory of the graphing calculator. Use the reset procedure below:
• Remove 1 AAA battery.
• Press and hold down the [DEL] key.
• While holding down the [DEL] key, replace the AAA battery, and press the [ON] Key.
The message Waiting... Please install calculator software should appear. At this point, it will be necessary to reinstall the calculator's operating system.
• Connect the calculator to the computer using the TI Connectivity Cable or DirectUSB Cable.
Please post if this was helpful...
• In Windows®, click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
• In MacOS® X, open Hard Drive >> Applications >> TI Connect >> TI OS Restore.
• Follow the directions on screen to reinstall the calculator's operating system.
Access the link following for detailed instructions on how to complete operating system installation.
Oct 14, 2010 | Texas Instruments TI-84 Plus Silver...
I have issues turning on my TI-Nspire using TI-84 Plus SE keypad
i would say use the normal key pad or send it in to T.I to fix.
Mar 12, 2010 | Texas Instruments TI-Nspire Graphic...
Broken screen on TI 84 Plus SE, TI83 plus and on ti73's I have about 25 graphing calculators. Students have simply scratched the clear plastic screen on 3 of the TI-73's. But the others have had the under...
I suppose they can be replaced. You should contact the TI Consumer Support Department at ti-cares@ti.com. They will be able to tell you where in your area of residence you can have the calculators serviced and how much It will cost you.
I have heard about a Casio program that gives credit towards the purchase of Casio calculators in exchange of TI calculators. Here is the link to the trade-in program.
I believe it is worth investigating this. You may end up replacing the calculators at a lower price. Casio calculators are very good and less expensive than the TI. You will be surprised to hear that Casio is the inventor of the LCD screen.
Mar 08, 2010 | Texas Instruments TI-84 Plus Calculator
TI84 does not work!
Perform a manual Garbage Collect.
  1. Press [2nd][0] to access (CATALOG)
  2. Press [TAN] to jump to first command that starts with G.
  3. Find GarbageCollect
  4. Press [ENTER][ENTER][2:Yes].Garbage collection may take up to 5 minutes
  5. After garbage collection is finished retry transfering data to calculator.
Uninstall and reinstall the TI-Connect software:
  1. Go to Start >> Settings >> Control Panel or Start >> Control Panel and select "Add or Remove Programs".
  2. Locate the TI-Connect software in the list and then choose "Remove".
  3. Once the software uninstall process has completed, please shut down and power off the computer.
  4. Wait approximately 20-30 seconds and then reboot into Windows.
  5. Download and install the latest version of the TI Connect software from the TI Connect Software home page.
  6. Once the TI Connect software install process has completed, restart the computer before using TI-Connect.
  7. Attempt to transfer data to the calculator.
If these steps do not solve the problem contact TI
Jan 30, 2010 | Texas Instruments TI-84 Plus Calculator
When I replaced the batteries in my TI-84 plus the screen now reads "garbage collecting" and nothing works. Any suggestions?
Whenever my calculator has said that, it usually takes a long time, especially if you haven't garbage collected in a while. I don't see why it wouldn't stop eventually, but if it seems like it never will, take out all the batteries and the back up battery behind the door with the screw. Leave them out for like a whole day. When you replace them it should reset your calculator.
Aug 09, 2009 | Texas Instruments TI-84 Plus Calculator
Ti85
kinda. The TI-85 programs differently, lacks a table feature, is not upgradable, has redefinable keys, has a larger screen, is smaller, energy efficient, TI-86 semi-compatible, and is older.
The TI-84+ has archive memory, flash-upgradable, FSTN (clearer) screen, 16*8 screen, USB On-The-Go compliant, almost a centimeter longer, assembly language support, and a tad bit faster.
TI-82: $89
TI-83 Plus: $79-99
Free TI-85: $0
TI-84 plus: $119.99
TI-84+SE: $129-139
TI-89 Titanium: $149
Sep 06, 2008 | Texas Instruments TI-85 Calculator
Cracked Screen
my son dropped his and cracked the screen 2 days ago.Called TI no replacement parts.Spoke to the head of the math dept.at school he also said they have called for repair and no luck. Solution is we have to write a check to the school for $120 since they supply the calculator
Mar 09, 2008 | Texas Instruments TI-84 Plus Silver...
Garbage Collecting
graphing calulators work much like computers. The have RAM space so they can remember what you have done recently and stuff like that. So when it's garbage collecting it means it's trying to find more space. This generally means that you don't have much much ARC or RAM space left. You can see this under your memerory manager. (2nd + enter) then you can reset your calculaor(2nd plus 7 1 2) or you can go to memory manager and unarchive your programs. Fur an example you have TI 84. Most new TI 84 have sientific tools. so if you don't you it take away the archive (*) by pressing enter and then hit DEL. the more RAM space and ARC space should make it so it doens't garababe collect. Hope this works. i can help you more if this doesn't work. GOOD LUCK
Jan 24, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
336 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
