Question about Sony CLIE PEG-SJ22 Handheld
Clie PEG-SJ22 does not charge battery
Does anyone know how to get the sony clie to charge the battery. It stop working one day but got it working by trying to charge the unit but will not charge the battery. Have already tried a new battery, same result. Thanks in advance
  • 1 more comment
  • gordotech Dec 16, 2007
    Tried it many times already. Unit works when plugged into charger, even without the battery. The unit can't see the battery.
  • gordotech Dec 17, 2007
    OK, thanks, sorry no intentions of insult was intended
  • kklinesmith Feb 22, 2008
    yes I have the same problem. both chargers dont work and I have purchased a new battery with no success.
Carried in a pocket, the charger connector at base of SJ22 will collect much lint which then does not allow proper connection. Try using a toothpick or straightened paper clip to clean out this lint. So far over several years, that's solved my connection problems
Posted on Aug 07, 2009
Have you tried resetting the unit? There's a little button on the back that you can press in with a paper clip. That'll cause the unit to reset (you won't lose data) and then you might be good for charging.
Posted on Dec 16, 2007
  • Anonymous Dec 16, 2007
    Perhaps the battery connection points on the actual unit have become bent over time? Bent inwards so they are not making contact with the terminals on the battery itself?
    I suggest using a very small screwdriver or perhaps a push-pin to gently bend the electrical contacts outwards (towards the battery) so that they are sure to touch it. (You maybe also be able to bend a spring that holds the battery instead of the electrical contacts.)
    Another idea would be to use an electrical contact cleaner (or even a dry q-tip) to clean the contacts on both the unit and the battery.
    And for future reference, please don't rate a Solution as Inappropriate if it just simply didn't help solve the problem. The "Inappropriate" rating is reserved for things like spam or rude comments.
Little adapter that plugs into both sony clie sj22 and power cord is broken. How do I get another one?
Same thing happened to me. If you search Amazon for SJ22 sync cable, you should find some. I ordered $9.95 five-foot cable from Amazon (via Boxwave)--it says In Stock, but then they said it is no longer available, and I had to buy $15 version with retractable very thin cable--hope it lasts.
Downside is that computer needs to be on to charge device.
If you want to pay $30, the original package appears to be available at:
Jan 12, 2011 | Sony CLIE PEG-SJ22 Handheld
Does anyone know of online battery replacement instructions specifically for a...
WARNING: DO NOT ATTEMPT THIS OPERATION UNLESS YOU DO NOT PLAN TO UTILIZE A WARRANTY AND OR INSURANCE. OPERATION WILL NULLIFY 1: Buy a new battery for your specified pda model(EBAY,AMAZON) 2: Preform a pda to pc sync if possible 3: Buy or or make sure you will recieve a pda screw driver 4: Unscrew back, be gentle 5: Gently remove back with a flathead screwdriver 6: Locate the battery cable 7: Disconnect the battery from the pda 8: Connect new battery/ reattach back
on Feb 25, 2008 | O2 Xda Atom
I Have a Sony CLIE PEG-SJ22 that I want to get internet on!!!
Hey dude. You don't even have a built-in browser in that handheld. What use can it be of even if you can get wifi to work on it? In addition, this thing has a CPU clock speed as fast as a 80486 Intel desktop CPU, even if you can browse the internet, it will take forever to finish loading a page. Oh, do you know that it only has 16MB internal memory for everything? If you want to check email, use outlook or palm desktop to receive them and sync it to your Clie. This is the closest you can get to the internet with this handheld. Goog luck and don't forget to amaze me by posting a real solution up if you can find anything, I mean anything, better than what I just said.
Mar 06, 2009 | Sony CLIE PEG-SJ22 Handheld
Palm talp hasent working.
it was cleared by my friend.
Jan 25, 2009 | Sony CLIE PEG-SJ22 Handheld
Screen Problem with my Sony CLIE PEG-SJSS
All you have to do is:
Look in the very bottom, right hand corner of the touchpad. You will see a little cog, click that and set it to whatever you want!
Oct 23, 2008 | Sony CLIE PEG-SJ22 Handheld
Sony Clie sj22
Oct 14, 2008 | Sony CLIE PEG-SJ22 Handheld
I'm in the process of changing from SJ22 to Smartphone running Windows Mobile 6.1 and I have found a way round this by sending data as vcard to myself in outlook then opening the attachment and saving and closing - this is then sent to your device on the next sync. It is a bit long winded but it works.
Open Outlook and leave it open.
In Palm, select the address you want to send, then in EDIT menu choose Forward as vcard, send and close the outlook pop up, saving changes.
Go to Outlook Inbox and open the attachment then save and close.
Aug 11, 2008 | Sony CLIE PEG-SJ22 Handheld
Sony Clie
I found there is an online tutorial which said to hold down the power button for a few seconds and the light comes back on.
Mar 31, 2008 | Sony CLIE PEG-SJ22 Handheld
Hot sync problems
Doe's some one out there have the software that came with the sony clie peg sj22/u
software version 1.1
Sep 26, 2007 | Sony CLIE PEG-SJ22 Handheld
Not starting up I get nothing!
Press the power button and hit the up button to reset to start.
I have the same issue and my palm battery will not charge and stil working on it. Try line 1 first
2nd option remove the battery and try without it. Then put the battery back in.
Hope this helps
Aug 07, 2006 | Sony CLIE PEG-SJ22 Handheld
Sony CLIE PEG-SJ22 Handheld Logo
251 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
