Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I just purchased an Honeywell RTH3100C thermostat to replace an older Honeywell Model. The older one has Y, W1, and W2. Y was jumped to W1 and E was jumped to W2. On the newer one I jumped E to AUX, and connected wire Y to Y, but I don't have a W1 to jump Y to. The manual says if the old thermostat had Y, W1, and W2 I need to contact a contractor for help.
  • pac1101 Sep 25, 2009
    The old thermostat is a Honeywell T8411R. Here's what I've learned by reading other blogs. I cannot verify it's accuracy.
    "The R and W posts on the thermostat are for heating, the R and Y posts are for cooling."
    From the T8411R manual located at:http://customer.honeywell.com/techlit/pd... I found:
    REMOVE JUMPER, WHEN SUPPLIED, FOR SYSTEMS WITH SEPERATE HEATING COMPRESSOR CONTACTOR (W1 SEPARATE FROM Y).
    While the jumper was in place from Y (yellow wire)to W1 on the T8411R, there was no wire connected from the heat pump into W1. So for now, Y is connected to Y on the RTH3100C with no additional jumper to a W1 (since there isn't one) and all seems to be working.
    I did connect E to E and put in a jumper between E and AUX on the RTH3100C(i.e. I treated AUX on the RTH3100C as W2 on the T8411R).
  • pac1101 Sep 26, 2009
    Correction: The last statement of the above comment is incorrect. What I did was connect the wire that was connected to W2 on the T8411R to AUX on the RTH3100C. Then I placed a jumper from AUX to E on the RTH3100C. Same effect, but there was no wire connected to E on the old T8411R, it was just jumped off of W2.
jgwhomeequip
  • 1902 Answers
SOURCE: heat will not shut off
Take white off of Aux, and attach it to L
Posted on Feb 16, 2009
SOURCE: Wiring
This will depend on type of system, standard high efficent furnance or heat pump. The orange terminal is for the reversing valve on the heat pump for the cooling cycle. Your best bet would be to get a thermostat that is fitted to your furnace instead of a universal t-stat. If I knew what brand of furnace, I could be more help.
Posted on Jun 01, 2009
jeffbvegas1
  • 520 Answers
SOURCE: wireing a honeywell thermostat
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Posted on Jul 24, 2009
  • 149 Answers
SOURCE: where does the W2 wire go?
w2 wire is second stage heat does your furnace have two stages.look at gas valve it would have 2 valves/ sol w2 will go to w2 on stat. if a single stage furnace w2 is not used
Posted on Jan 25, 2010
hvac1960
  • 2133 Answers
SOURCE: Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Posted on Dec 02, 2010
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
RTH3100C thermostat for an older Lennox heat pump
well the wire on x will go to e thr r is the red wire goes to r the wire on f willgo to g the y will go to y now the rest you'll have to verfy at air handler o will go to reversing valve common wire will go to c the electric heat will go to aux
Feb 06, 2014 | Honeywell RTH3100C - Digital Heat Pump...
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Where does the W2 wire go?
Jan 25, 2010 | Honeywell Programmable Thermostat Heater
Wireing a honeywell thermostat
Jul 24, 2009 | Heating & Cooling
Honeywell Thermostat
Make sure G from indoor unit goes to G on thermostat for fan continous fan, if that doesn't work and you have 24 volts to R and C then the t'stat is bad.
For 2nd stage heat or aux.heat, on the indoor unit you need to make sure the wire W2 from the indoor unit goes to W2 on t'stat.
You don't need any wires from W1on the indoor unit to W1 at the t'stat because with a York heat pump Y1 is the contactor which turns the compressor on and you will get 1st stage heat, and for cooling the t'stat will also bring on O which is the (reversing valve) or cooling changeover relay for the cooling mode.
C = common usually black wire
R = hot usually red wire
Y or Y1 = contactor
W1 = 1st stage heat not needed for heat pump
W2 = Aux. heat indoor heat
G = fan
O = Cooling changeover relay
B = Heating changeover relay
L = System monitor
E = Emergency heat relay
Dec 23, 2008 | Honeywell Electronic Programmable...
I had an old thermostat that i had to change need wiring diagram
both thermostatats will have terminal designators R,W,Y,G, possibly O/B, C, W1,W2, Y1, Y2, etc.
Simplest method is to remove wires from old stat one at a time. mark where they came from and then install at same desinated terminal on the new t-stat. Hope this helps. be sure to shut off power supply to the unit (furnace) first. The wire coming to the R (RH,RC) terminal is the 24 volt a/c hot, all others are feeding back to perform given function.
Dec 20, 2008 | Honeywell Programmable Thermostat Heater
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
544 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
