Question about Bosch 24 in. SHU43 Built-in Dishwasher
Sounds like water....dx doesnt work
Machine does not wash although 2H light comes on and you hear some liquid sounds going on. tried control panel dx sequence but even dx sequence doesnt work.
  • 130 Answers
2H means the machine is taking longer than 99 minutes to run a cycle. Start the cycle and wait 5 minutes, then open the door. If water doesn't look like it is spraying out the wash arms or slowly coming out the wash arms, then check to make sure the filter at the bottom is clean. If clean, then sounds like your circulation pump isn't running or impeller has came apart.
Posted on Jan 06, 2008
Not water comes into Bosch dishwasher?
Assuming you have verified water is actually getting to water valve, most likely water valve is the problem and needs replacing.
Sep 10, 2017 | Bosch Washing Machines
Make sure that the water is turned on. Carefully under the main control panel if you lift it up when the water should be on you should hear the water inlet solenoids clicking on then off, if not make sure that the wires are connected UNPLUG FIRST BEFORE TOUCHING ANY WIRES
Dec 28, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Water doesnt stop when filling washing machine
There should be a "fill control" on the panel of the achine that lets you set the fill limit for wash loads ranging from small to large. Obviously, your fill control is not working
Oct 09, 2012 | Washing Machines
When u start it it just make a buzzing noise but doesnt fill with water
Hi, if there's no water at all, make these checks:
Is there water getting to the machine?
Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 13, 2011 | Washing Machines
We have a Whirlpool WFS1071BD. We are on tank water (rain water), with resultant poor pressure. We're finding our washing is increasingly smelly (mould?). Is there anything we can do/put through to make it...
epsom salts are the only thing that makes a difference tried all the new gear doesnt work as good as epsom salts every two weeks 1/2 cup on hot wash with no clothes & use cold power advanced washing powder this is the best way of keeping control of it once you get it clean you have to keep on top of it the smell doesnt take long to come back with out continues treatment.
Jan 10, 2011 | Whirlpool Washing Machines
Water in drum
The swish water sound that you hear in the drum is normal. There is some liquid in the drum for balancing. The washer doesnt use that liquid for laundry. The odor smell - you can get rid of it by cleaning your washer. Run empty cycle with bleach and hot water at least once a month. Also use washer cleaner - Tide recommended for a nice cleaner smell. You can get it from any supermarket.
Sep 29, 2009 | Samsung WF203ANW Front Load Washer
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Kenmore Front Load Washer on the blitz
remove bottom panel and ck pump for obstruction especially if water is still in tub
Jul 21, 2008 | Kenmore 43142 Front Load Washer
Prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
Jun 24, 2007 | Bosch SHU5307UC Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
222 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
