Question about Kitchen Ranges
I own a Rf396pxyq0 whirlpool Electric range.I'm having trouble with the oven in the bake mode building up to the temperature set on the elect control pad.when turning on the bake mode the lower burner heats only moderately and never gets red hot like it should. The upper broiler burner does come on in the bake mode and appears to be okay because I tried the broil mode and it gets red hot pretty quickly.When you turn on the bake mode,you can hear it click on as it goes thru its cycle to raise the temp to get to 350 however it takes forever to get up to 350 and then a oven thermometer reads 280 degrees.The lower burner at this point does not get red hot like it should.I checked the lower burner continuity and it is okay and I replaced the temperature probe but still got the same results.Could you please tell me how to check continuity on the remaining items that may be causing the problem and the readings I should be getting Can you speculate what the defect might be. elec control panel circuit board,clock,wires from both burners,fuses or relays if any on this model ?
  • gmwoolf454 Sep 25, 2009
    Can you please provide details on testing the circuit board and clock to pinpoint the defective component.
    Thank you.
  • 15,935 Answers
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
CLICK HERE to see the "clock" assembly - It controls and regulates all functions of the oven. Since you have checked the elements and thermostat already - you're down to the last component....
However it is always my recommendation that if a repair is to cost more than 1/3 of a new one - to put the money toward a new appliance.
The new one will save money by being more efficient, and will have a 3-5 year warranty.
The controller board is not difficult to replace (a few screws and wire harnesses), but is pricy at $250 (white) or $185(black)
Thanks for using FixYa!!
Posted on Sep 25, 2009
  • blueextc3221
    blueextc3221 Sep 25, 2009
    The digital programming function is stored in EEPROM and not serviceable. Once the module is faulty - it must be replaced in whole.
    The module in question is directly in the center of the board. Looks like a computer chip. It does all the calculating and relaying functions.
    It is not seperately serviceable. You CAN swap it out - however FINDING the part is going to be impossible - unless taken from another non-working controller that doesnt have the same problem.
    Thanks
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Top burners OK. On convect bake the oven will heat up to set temperature then shut off and cool down. Normal bake function seems to work ok.
PDF]BUILT-IN ELECTRIC CONVECTION OVEN - Whirlpool
https://www.whirlpool.com/.../Use%20and%...
Whirlpool Home AppliancesBUILT-IN ELECTRIC CONVECTION OVEN. Use & Care Guide ..... To Turn TonesOff/On: Touch and hold COOK TIME until a tone sounds and the lower oven ...
Teach me how to use my convection oven - Chowhound
Jan 01, 2016 | Maytag MES5875BAS Slide-In Electric Range...
Oven shuts down while baking
thermostat my be brokenit thinks its hot so it shuts the heat off....
Apr 21, 2014 | KitchenAid KERS807SSS Electric Kitchen...
Oven shuts off while baking and will not restart till oven cools off??? thanks mark
Good Afternoon Mark,
I see that you're having trouble with your Frigidaire range, model# PLCS389DC, shutting off in mid-baking, and will not restart until the oven has cooled. It sounds like it is either the temperature sensor, that is sensing a runaway oven temperature, or the control board itself that might need replacing. I suggest contacting you local authorized technician for further assistance. They will be able to determine what exactly is causing your oven to cut off in mid-baking.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire PLCS389DC Dual Fuel (Electric...
Electic range oven won't maintain temperature
What is the complete model number of your unit?
Feb 18, 2013 | Kitchen Ranges
I had the E2 F3 code while I was baking something. Is it safe to eat the food that was in the oven at the time the error occurred?
F3
- E2 Oven temperature is too high (Cook
mode)
Replace
Oven temperature sensor (RTD)
Note: Applies to all
F3-E... codes.
Dec 21, 2010 | Whirlpool GR460 Electric Kitchen Range
Frigidaire range model #fgfl67dcf needs to be calabrated, too hot for setting
OVEN CALIBRATION Set the electronic oven control for normal baking at 350°F. Obtain an average oven temperature after a minimum of 5 cycles. Press CANCEL or CLEAR to end bake mode. TEMPERATURE ADJUSTMENT 1. Set EOC to bake at 550°F. 2. Within 5 seconds of setting 550°F, press and hold the bake pad for approximately 15 seconds until a single beep is heard (longer may cause F11 shorted keypad alarm). 3. Calibration offset should appear in the display. 4. Use the slew keys to adjust the oven temperature up or down 35°F in 5°F increments. 5. Once the desired (-35° to 35°) offset has been applied, press CANCEL or CLEAR. Note: Changing calibration affects both Speed Bake and normal bake modes. The adjustments made will not change the self-cleaning temperature.
Jun 18, 2009 | Kitchen Ranges
Whirlpool Accubake - Can't get out of clean mode
cannot get out of clean mode, although the oven outside is cool, but door is locked and display still says cleaning, door locked and time of 3 hrs 15 min is displayed. NOW WHAT?
Nov 16, 2008 | Kitchen Ranges
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
