Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Receive message 345 and alarm which prevents operation.
Happened after sending a fax for a friend. dont know if related but when i went to use copy facility alarm light came on and #345 appeared in top left hand corner.
Have rel;oaded whole system and problem still exists
    Habit-Forming:
  • 71 Answers
Other Canon models "may" be repaired with these instructions also, for example MP370, MP390, etc. Try with your own risk.
Symptoms:
-Grinding noise (very loud)
-Flashes error code ##345
Error code ##345 = "BJ cartridge head cleaning error" -reasons for this are:
-Foreign material or dried ink in head cleaning unit (also known as "purge unit") , or waste ink pump jammed up. Make sure waste ink pump rotates freely, after cleaning. Clean the waste pump-hose too! Waste ink pump is located under head cleaning system.
Short solution:
1.Take apart and wash the ink clogged mechanical parts. Use hot water.
2. Reset waste ink counter
purge unit: HM1-0723-000
see more parts: http://www.e-parts.fr/pictures/uploaded/files/MP_360_370.pdf
I hope this is useful
Posted on Oct 04, 2009
Cannot fax message ringing
Hello sir; try to replace another phone cable should be tak care your problem, good luck
Nov 01, 2012 | Epson Office Equipment & Supplies
Cannot send faxes
check whether you have loaded the scanner software .
Sep 03, 2008 | HP Officejet 4215v All-in-One Printer
Fax machine is able to receive faxes, but not able to send them. There is a "No Response" message every time I try to send a document.
Hi, i think your fax machine works fine, A "no response" message indicates that the receiver should accept your fax by hitting on the start button (normally its a green button) for you to able to send a fax or if no one in your friends location is receiving it. In this case you might as well set your fax machine to auto receive fax, defends on your fax machine's model. i hope this helps.
Aug 04, 2011 | Office Equipment & Supplies
My AT&T Xenon LG not receiving texts. A friend thought it would be a funny joke to send copy-and-paste of a lengthy website 50 times as a text. Now I am unable to receive texts; however, my friends...
Did you ever find a solution to this problem? The exact same thing happened to my friend two days ago. Someone sent them the same message repeatedly, and he can no longer receive any messages, other than multimedia.
Oct 28, 2010 | LG Xenon GR500 Cell Phone
I dont know how to send faxes woth my canon mx310. Where do i put the phone line in the spot that says L or under the picture of the phone?
You need to use your PC to send/receive faxes. You cannot directly use your printer to send/receive faxes. I dont know what operating system (e.g. Win7, Vista, Mac) you're using. But if it's windows, you can find instructions on how to set it up by clicking on the link below.
http://tinyurl.com/2b37whh
Hope this helps.
Oct 24, 2010 | Canon PIXMA MX310 All-In-One Printer
Scanner locked message on display. Will not copy
Check if the transit lock may have engaged due to movement. These locks prevent the scanner from moving while moving the devices during shipping. They sometimes engage by themselves.
Mar 23, 2010 | Xerox FAXCENTRE 2218 18PPM FAX
Fax can do copies and send but not able to receive incoming faxes. Did several tests. Modem picks up but doesn't transmit data. LCD screen does not indicate any trouble or alarm.
It's possible that somehow the incoming faxes are going directly to memory and not printing. If there was a Tx issue, you'd get an error message on the LCD screen or a printed out message. Not knowing what kind of machine you have, I can't give you instructions to print from memory but if you check your manual, you should see instructions to both print from memory and set the fax to print automatically.
Nov 18, 2009 | Office Equipment & Supplies
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Sony ericsson w910i :problem with send/receive sms
you don't have to do the complete master reset..this happened to me yesterday and i did 'reset settings'. it works as well and you dont have to move any of your files. :)
Oct 01, 2008 | Sony Ericsson W910i Cellular Phone
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
393 people viewed this question
old marine
old marine
