Question about Panasonic TH-58PX60U 58 in. Plasma HDTV
Dead, when turned on, power light blinks seven times, pauses then blinks seven times.
  • 135 Answers
Power supply fault
Posted on Sep 25, 2009
Panasonic TC-P55UT50 plasma went black. power light blinks 7 times, pauses blinks 7 times. Is this a power board? or Y-Sustain?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 06, 2016 | Panasonic Viera TC-P55UT50 55" 3D 1080p...
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
Mitsubishi WS-55819 turns off after about one second upon power up. Help
try the self test: when it goes off press and hold the menu and input buttons at same time for about seven seconds and release both.
power light blinks two digit code like, one blink, two blink, a pause and repeats it several times, this code will indicate area of problem.
sj
May 17, 2011 | Mitsubishi WS-55819 55" Rear Projection...
The dish washer starts to fill then stops and starts again then stops and the red light blinks on and off
Does it blink seven times, pause, then seven times, pause, seven times, etc. ?? If so you may have a bad heater element. Or the water temp into the D/W is not hot enough. Most machines require at least 120 degree water to work properly. Take a close look at the heater if it looks ok you'll have to check it and the heater circuit with a meter. Turning the breaker off for 7 to 10 minutes will reset the control board but wont fix the heater of course. Good Luck
Mar 12, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore DW blinking clean light 7 times, pausing, blinking 7
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Oct 11, 2009 | Dishwashers
I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Jul 17, 2009 | Hitachi P50H401 50 in. Plasma HDTV
2004 Sony 52" Wega dont turn onnthe stand by light stays flashing. This TV first started by taking long to turn on and now and then would turn off until one day it just didnt turn on and the standby button...
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
Jun 14, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Panasonic TH-58PX60U 58 in. Plasma HDTV Logo
303 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
