Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
Wont run I have power to the unit but it wont run i have no lights on the unit
    Scholar:
  • 191 Answers
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Jul 19, 2008
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
Power light blinks wont run
What is the model number of your unit?
Nov 07, 2012 | Refrigerators
Vizio 26L wont come on
Common problem with this model. The capacitors in the power supply board have failed which is keeping the unit from fully powering up. Here is a link to some information on which capacitors need to be replaced to get the unit back up and running.
http://www.ccl-la.com/catalog/product_info.php?products_id=58
Aug 19, 2012 | Vizio VA26L 26 in. LCD HDTV
Machine wont power on
if the unit does not power on at all no lights or fan running . then you need to replace the power supply.
May 13, 2010 | Acer Aspire L100 PC Desktop
Computer wont turn at all worked fine the night before moniter works no lights dvd door wont open
if the unit worked last night and now it will not turn on then it's one of two issues. first we need to look at the unit are there lights or can you hear a fan running . if so your motherboatrd has failed , and the fact that most dell mobo's have intergrated video you couldn't see anything at that point. two if there is no lights or fans running and you can not open any drives then your power supply has filed . decide witch one and let me know if you dell is still under warranty i can call and do a warranty claim and get them to send parts and a tech if not give me the service tag number and I can find part numbers for you . hope this helps
May 13, 2010 | Computers & Internet
Fan @ compressor wont run,one light is flashing
flashing light is showing an error code. if the unit is under 5 years old it will be covered under warranty.. if you want you can try and reset the power by turning it off at the isolator next to your outdoor unit, leave it a couple of minutes and switch it back on. this will reset the fault code, if the flashing light comes back there is a definite problem, if it runs the fault may have been caused by a power surge or something
Dec 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Wont charge while powered on or run on ac power
Sounds like a lose or burnt charge terminal.  Fixing would require disassembling the laptop and resoldering the loose or broken connections.  You might want to try a different AC adapter first.
Apr 21, 2009 | Toshiba Satellite A75-S211 Notebook
Dometic rm4223 wont run at all
Make sure you have 12 volt DC power to circuit board. If you do you need a circuit board.
Feb 15, 2009 | Dometic WA3210 Compact Refrigerator
Unit wont start up after power failure
Answer on fixyourownprinter.com. Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Jul 30, 2006 | HP PSC 2510 All-In-One InkJet Printer
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
211 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
