Question about Dryers
Belt needs to be put on - Dryers
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    BRAND NAME and MODEL NUMBER needs to be provided.
  • Dryers Master
  • 8,404 Answers
Piece of cake.
Remove the top ... may be a couple screws - then pull it up off the spring clamp.
Remove the front. The drum will come with it. Remember, there are wires on the front ... dont mess em up.
Get your new belt - put it around the drum ... then ... and this is the tricky part ... stand on your head and start whistleing!
The belt goes through the tensioner and around the pulley on the motor.
Lift the drum back to the rear wheels and the front bearing.
Refasten the front
Put the tolp back on
Vola!
Oh yea ... unplug it first.
Need parts ... local source ot RepairClinic.com
Let me know how you make out.
a
Posted on Sep 25, 2009
Passat serpentine belt diagram v6
Here's a link to your belt,put wrench on bolt a tensioner,turn to take tension off,then remove belt,need 2 people to do this. 2000 Volkswagen Passat Serpentine Belt Routing and Timing Belt Diagrams
Sep 08, 2014 | Cars & Trucks
Tip
Changing inside pully belt
if you have two belts on your vehicle and need to change the inside one , put the edge of belt one pully that has outside belt and hit key couple times (do not start) the pulley and belt on the outside will turn putting the inside belt on inside without removing outside belt , Will leave small mark on belt that you put on But will not hurt it
on Sep 19, 2010 | Chevrolet Blazer Cars & Trucks
How do I put the serpentine belt back on a 1998 saturn sl2 after I have installed a new alternator
there is a little stick man illustration sticker under the hood showing how to release belt tension by moving the tensioner arm. if the serpentine belt is still on the lower pulley then put the belt on everything except the tensioner, then move the tensioner arm as needed, put the belt in there and release the tensioner arm. most likely going to need two people to do this.
if the belt has come off the lower pulley then you are going to have to remove the service panel behind the right front wheel and put the belt back on lower pulley, then do as above described. this would be a great time to put a new tensioner, a new serpentine belt, and a new "dog bone" motor mount on as it will all be right there to work on with that service panel out.
Apr 03, 2011 | 1998 Saturn SL
Serpentine belt digran pontic sunfire 2000 belt digrqam needed need digram to put serpentine belt back on
need to know the engine size and you should have a diagram for the belt routing under the hood. if the belt tensioner is faulty or one of the pulleys have seized .have those repaired first instead of putting on the belt again.9 out 10 it is a faulty part that is why you may have lost the belt.
Jan 25, 2011 | Pontiac Sunfire Cars & Trucks
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Hoover windtunnel vacuum belt
There are 4 screws that you need to remove. The belt lies between the roller and a pin. With a little effort, you just pull out the roller, and the belt will come loose. When putting the new belt, you need to insert the belt into the pin first and then put the other end of the belt onto the roller. Then pull the roller and put it back into its groove. Voila!
Aug 19, 2008 | Vacuums
Dryers Logo
Top Dryers Experts
