Question about Mtd 22" Yard Machine Push Mower
Re: primer button
Thanks I got a new primer button from a mower repair shop he showed me how to get the old one off & replace it. Thanks for your help
  • 78 Answers
When posting please indicate the model number if you are asking about an engine part. If its Briggs and about 4.5 hp ,there is a tab on either side of the primer and that releases the primer. Smaller engines are held in with a metal ring
Posted on Oct 27, 2009
  • Roger Geer Oct 27, 2009
Need a repair manual
undo the screws holding the ring around the primer bulb and take it to a mower shop for a new one
refit as was removed
Mar 25, 2016 | Garden
4 lawn mowers same problem wont start until I prime the by hand. Briggs Stratton 917.387500/ 12AV566n01124987/20043/SDSP2245D Will the same primer bulb fit the above mowers.
If its identical it should work ,if not take the old one to a mower shop,to get correct one and make sure the choke is going right on when the cable is in choke position.
Aug 05, 2014 | Ryobi Snap In Primer Bulb Pump 683974 ...
Engine diagram tecumseh prism 37
Probably cracked, easy to replace. Take model no. off MOTOR not mower to mower repair shop to get primer button replacement kit!
Jun 26, 2013 | Garden
Primer bulb
hello take the old bulb and go to your local mower repair shop,,
Feb 01, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
My briggs and stratton 158cc 500series push mower primer button melted from sun. how do i replace it?
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
May 09, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
Primer bulb has split. Is it possible to replace it & what is the part number?
Most small engine repair shops have these primer bulbs and they are available at Home Depot or Lowes. I replaced mine from a value pack purchased at Lowes for around $6.00, it came with 3 different sizes and took 2 minutes to replace.
Jan 11, 2011 | Garden
My primer button as broken how to replace it and where to buy the
Lowes Home Improvement store carries them, also lawnmower repair stores have parts departments that have them. Mine cost about seven dollars.
Apr 19, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I BOUGHT A BRAND NEW TORO LAWNMOWER, MODDEL 20330,
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Apr 08, 2010 | Toro Lawn Mower With Toro Power Tools
Mower shuts off 3 seconds after priming
Briggs made primers with and without holes in them. In my shop it is common to see them transposed on engines.
Take down the MODEL TYPE CODE numbers and check here to see if yours should have the primer with or without the hole in it.
Click the Parts Lookup box in the center of that page.
Next, drop down the menu on the left to Briggs & Stratton. Set the tab at the top to MODEL.
Next, type in the model number and click search.
From the results page, select your exact type number. Your individual parts views will then be listed on the right side of the page. You'll get the idea!
Hope this helps.
Sep 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
My primer (clear button ) is cracked. Does any body know were I can buy one? Homelite SX 135
Lowes or Homedepot sell replacement primer bulbs. You can also get one at any mower repair shop.
Jul 19, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
136 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
