Question about Mustek TwainScan 600 III EP Plus Flatbed Scanner
My daughter has acquired a Mustek 600 III EP Plus scanner, unfortunately without a power supply. I know it is 15 volts 1 amp dc, but is it +ve or -ve tip?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 201 Answers
Mustek 600 III EP Plus scanner, Power adapter type output +15VDC/1A Positive Polarity (positive inside and negative outside).
Posted on Nov 09, 2009
Drivers for scanner
http://mustek.com/product_resources/drivers/scanner/parallelport/600IIIepplus/win31-95-nt/63EP322.EXE
Dec 11, 2009 | Mustek TwainScan 600 III EP Plus Flatbed...
Mustek EP A3 What power supply do I need for this?
Mustek EP A3, power supply input range is 100 Vac~250 Vac, 47~63 Hz, power consumption is 1.0 A, 15 V.
YBC (/\)
Nov 09, 2009 | Mustek TwainScan 600 III EP Plus Flatbed...
Need to download Software for Mustek 600III EP Plus
you can download the software in manufacturer's official website for free.
Jan 26, 2009 | Mustek 600 III ep plus scanner
Scanner Mustek mod. 600 III EP -[ Plus
Hola Julian: Eso que comentas es el power de tu scanner, puede ser conectado a cualquier toma corriente de tu casa con el adaptador adecuado y no necesariamente a tu computadora.
Pasa que algunas computadoras como la tuya tiene entrada de power para conectar este tipo de devices para darle corriente a los scanner, parlantes o cualquier device externo que necesite power.
Ese cable lo conseguis en cualquier store de electronica, es un bridge. (un puente de corriente entre tu compu y el scanner)
Sino la otra alternativa es conseguir un power supply para tu scanner. Eso es todo.
Aca tenes el power supply:
http://cgi.ebay.com/15HB-power-supply-ADAPTER-15v-1A-HP-Mustek-UMAX-scanner_W0QQitemZ370092779651QQcmdZViewItem?hash=item370092779651&_trkparms=72%3A1156%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Oct 04, 2008 | Mustek TwainScan 600 III EP Plus Flatbed...
Tipos de conectores para Power 120v - 15 volt
Mustek 600 III EP Plus scanner, it doesn't matter what is the adapter input voltage is (base on your local country power supply voltage), but as long as the adapter output plug in your scanner is +15VDC/1A Positive Polarity (positive inside and negative outside), then your scanner will work.
Oct 02, 2008 | Mustek TwainScan 600 III EP Plus Flatbed...
Drivers are available from the mustek web site in US or Taiwan. See http://www.mustek.com.tw/Download/driv_scanr/english/600iiieplus.html.
You need an AC power adapter if you don't have one. The original was an YHI Power Adapter, model YC-1015-15, Input 100-120V, 60 Hz, 0.4A, Output +15VDC/1A. I know because I'm reading it off of mine (I am the original owner of one, this is about 10 years old). You can find new ones on eBay for $10 plus shipping.
Finally, you need a cable that connects the scanner to the PC using parallel port technology. Both ends are 25 pin Female, and the cable itself is marked as IEEE 1284 compliant. Cable is AWM E101344 Style 20276 30V VW-1 Space Shuttle. Must have 25 pin female connectors, check eBay or http://www.driverforum.com/controller5/10421.html.
Sep 10, 2008 | Mustek TwainScan 600 III EP Plus Flatbed...
Mustek scanner Hang up
Hi leon,
Re-install again the driver of your scanner, machines hangs up because of the operating system got a problem working with it.
Enjoy
tnx
-micro
Feb 10, 2008 | Mustek TwainScan 600 III EP Plus Flatbed...
Flatbed scanner
take a volt meter and check the power at the end of the power adapter, sounds like it may be a power issue. if all is ok on that end does it still work on the old system? you may have to hook it back up to a working system and see if there is a firmware upgrade for it. Best of luck
Dec 29, 2007 | Mustek TwainScan 600 III EP Plus Flatbed...
Mustek TwainScan 600 III EP Plus Flatbed Scanner Logo
256 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Mike
Computer Links
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
