Question about Sharp Microwave Ovens
How to set the clock on my sharp carousel microwave
Touch STOP/CLEAR pad.
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
Posted on Mar 11, 2010
  • 1 more comment
  • freideleebs Aug 15, 2011
    I tried this method (found on many other sites as well) and I keep getting an ERROR message. it just won't let me set the clock :-(
  • Christopher Flynn Feb 12, 2012
    Did you ever find out the answer? I have the same problem......
  • Oleg Urzhumtsev
    Oleg Urzhumtsev Oct 06, 2013
    It takes only 12-hr format with leading 0 (e.g. 0215 for 2:15, both am and pm)
If the time is *NOT* a four (4) character (i.e. 2:15, 6:30, 9:45, etc), you need to insert a zero before the other characters (i.e. 0215, 0630, 0945). That may be why you're getting an error message.
Just a thought...
Posted on Feb 11, 2012
Help, i m having the same problem setting the clock. Everyone has a different answer. Please help
Posted on Sep 05, 2011
  • Sarah Burnham Oct 03, 2013
    Hit Stop/Clear, hit Timer/Clock, enter 4-digit time, eg 0830, hit Timer/Clock again. Sets the clock.
    To use the timer, enter the number of minutes/seconds you want and hit Timer/Clock. Worked for mine.
Hi solved the problem by pressing clock set inter the time then press and hold clock set for 2 seconds this step is not incloded in the manual and then press start the clock will work after that.
Posted on Aug 17, 2018
Guys are all giving the wrong answer. This does not set like a usual microwave. I've tried. Must see sharp.com
Posted on Jul 16, 2012
  • gaybee Nov 06, 2013
    Press Timer/Clock button until the ":" blinks. Then set the time i.e.12:04, then press Clock/Timer button again. You are set!
5 Suggested Answers
SOURCE:
  • 110 Answers
SOURCE: i have a sharp carousel
The easiest way I can remember is to turn off the power, then back on... this will make the display flash, then press stop/clear.
Then press clock, enter the time eg: for 9 am or pm enter 9.00 and press clock again.
Hope this helps.
Posted on Apr 25, 2008
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
Posted on Oct 13, 2008
MicrowaveSvc
  • 9156 Answers
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
The service manual (available at our site) shows how and shows that the lamp is mounted in the air duct near the magnetron. See http://www.microwavedisplay.com/r510hk_hw_sm.pdf
Part # is RLMPTA086WRZZ and you should be able to get that generically locally but if not, you can get it form Tritronics at http://www.wehaveparts.com
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Nov 22, 2007
fieldy14
  • 456 Answers
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
Posted on Aug 16, 2009
Hurricane irma, have electric, sharp carousel microwave willnot program any ideas
Un plug for a few minutes, plug back in, set the clock ( time of day) try again.
Sep 28, 2017 | Sharp Microwave Ovens
How to fix Sharp Carousel Microwave Oven R-303CW clock not working?
The clock is part of the control board and cannot be repaired as a separate item. Most replacement control boards costs as much as
a new microwave.
Jul 15, 2014 | Sharp R-303CW Convection / Microwave Oven
Sharp carousel microwave
You may need your main control panel repaired
Oct 21, 2013 | Microwave Ovens
I can't set the clock. It's a Sharp Carousel II w/ ESP - R-4K82C
Press the clear button twice and then the clock button. You can now enter the time. Press the clock button when set.
Jan 03, 2011 | Sharp Microwave Ovens
Unable to set microwave clock
sometimes the clock resets after unpluging for a short period. when you restart / power up note the time it starts at generally 12:00 miday good luck gbw
Feb 07, 2010 | Sharp Microwave Ovens
I have a Sharp Corousel Microwave R230KW.
On most Sharps, the sequence is:
Clock > 2 > 3 > 5 > Clock (for 2:35)
or
Clock > 2 > 3 > 5 > Start (for 2:35)
You can order many Sharp manuals free here.
William E. Miller
prototech@usa.net
Sep 26, 2009 | Sharp Microwave Ovens
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
I have a sharp carousel microwave and need to set the digital clock on it but dont know how. could someone please help.
Hope this helps.
Apr 25, 2008 | Microwave Ovens
Microwave Ovens Logo
15,804 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
