Question about Lexmark X342n All-In-One Laser Printer
Lexmark x342n 290 scanner jam remove original
Screen display: 290 scanner jam remove original
the control pannel buttons all has no response
Soulvisitor
  • 1113 Answers
SOURCE: lexmark x342n
A 902 Service Engine Software error indicates a failure in the engine board software, power off clear print que on pc print driver then power up if problem persisits see this link
http://www.marketpoint.com/article.cfm?id=119
Posted on Oct 29, 2007
SOURCE: Lexmark X342n MFC cannot print faxes
Contact Lexmark and get updated firmware - had this problem on an X342n unit yesterday and applying an update (now shows firmware LC.MD.P114 ), faxes started receiving properly.
Posted on Jan 09, 2009
  • 93 Answers
SOURCE: lexmark x342n printer paper jam
Remove the jammed paper by gently pulling it straight out of the MFp
Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for service you will need your printer model type and serial number. If you need help locating this information, click here.
Posted on May 31, 2009
  • 68 Answers
SOURCE: Photoconductor my printer Lexmark X342n is low...
The photoconductor needs to have life left in it for printing and scanning.
Posted on Jun 13, 2009
don_farr
  • 1011 Answers
SOURCE: Lexmark x342n Printer Driver
Please go to www.lexmark.com. Then select drivers and download. Put the printer model number into the first search bar and then find the correct driver for the operating system that you have. Don
Posted on Jun 14, 2009
How to scan from a lexmark x342n to my laptop.
Firstly, download the drivers from this location:
http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X342N&focusedTab=DOWNLOADS#1
Specifically this one:
Local scan driver for multifunction printers X34x
After you have installed it you should see the device under Control Panel> Printers> Scanners and cameras
Mar 09, 2011 | Lexmark X342n All-In-One Laser Printer
Having problem with paper jam. sometime it display error 200.13 or 200.20 and some time it says 34 short paper.
Please make sure that the paper settings on the printer is in sync from the application you're using (e.g.Microsoft Word). Click on the link below and follow the steps on how to clear the jam. http://bitly.com/qb81bJ
If you need further assistance, please contact Lexmark Technical Support Center.
Feb 19, 2011 | Lexmark X342n All-In-One Laser Printer
I have a lexmark pinter/fax model x646e, i do not have the manual. when i am trying to make copies it reads" 290.01 scanner jam, remove all originals from the scanner" but there is nothing stuck. i have...
This is a hardware issue. Maybe the sensor, the pick arm or the pick roller itself that's causing the problem. Here's an article on Repeated '290' Paper Jam Messages Occur When Using the Automatic Document Feed (ADF) on a Lexmark X64x Series Printer. Just click on this link: http://bit.ly/clBsWr. If this doesn't help, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 26, 2010 | Lexmark X646e All-In-One Laser Printer
201.02 paper jam
Please open up the printer take the toner out, please there is a paper jammed in this location, Bring paper out put toner back and power on the printer
Apr 17, 2010 | Lexmark X342n All-In-One Laser Printer
Screen display 290 jam remove original
290/291/292 Scanner Jam
1 Open the ADF top cover.
2 Remove the jammed paper by gently pulling it straight out.
3 Close the ADF top cover, and then load the documents back into the ADF.
Note: To prevent document jams, use the scanner glass rather than the ADF for thick,
thin, or a mixed set of documents.
4 Press Start to resume.
Nov 12, 2009 | Lexmark X342n All-In-One Laser Printer
200.13 paper jam remove cartridge
The Lexmark x340 and x342n has 3 sensors that identify the path of the paper below it.
2 are below the feeder roll of paper and the other in fusion.
Clean the sensor or adjust the tamnho the paper tray to which the document is.
Vagner
Jun 19, 2009 | Lexmark X342n All-In-One Laser Printer
Lexmark x342n printer paper jam
May 31, 2009 | Lexmark X342n All-In-One Laser Printer
Lexmark x342n all-in-one printer paper jam
Is any part of the page imaged?
What is happening is that a paper sensor is either hung or jamed so that the sensor is incorectly reporting an error .
I would remove the cartridge and using a flash light search for any scrap of paper that may be in the paper path. If you can't find any, I would next looked for a sensor flag to see if it is jammed out of position.
Of course, you could always call a service tech or even better submit this question to Lexmark Technical Support for more in depth assistance.
Code 200.13
Replace Sensor Input Media and it should fine The part Number 40X1223 the cost around $3.60.
Apr 24, 2008 | Lexmark X342n All-In-One Laser Printer
Lexmark X342n All-In-One Laser Printer Logo
388 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
