Question about Dell Dimension 5100 (D51L1) PC Desktop
I have been going through hard drives 4 in the last 2 years and 2 in the last 3 months I was told that my mother board was losing power and causing the hard drives to fail
    President:
  • 2,600 Answers
Hard drives demand a steady constant power flow, or their controller cards can get fried or there can be mechanical damage from power spikes. Heat is another killer of hard drives, they need air flow and open space around them to "bleed" off heat. I would probably upgrade my power supply to a more modern one with separate power rails and make sure the drive is secured in the middle area of its mounting cage and maybe install an auxiliary fan just for moving air over the drive.
Posted on Sep 25, 2009
My EMachines tower computer worked great when stored 4 years ago. Now, why won't it turn on at all?
many thing of course last yr I bought a new dell laptop 3 months later it would not work . dell told me it was past it's life expextency before I bought from walmart and would not fix or replace
Apr 27, 2015 | Computers & Internet
Motherboard Respected Sir, In Intel mother Board there is No Signal / Display, its dead. For your information its under warranty, purchased from Net com Systems & services - laxminagar.but not...
if it is still under warranty you should not attempt to fix it you might lose any warranty you have
contact them ask for someone with a high ranking to help assist you with this warranty claim
if you want to test it yourself do not tell them you have touched it
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Mar 13, 2011 | Intel DG31PR Motherboard
My acer 3690 laptop knocks itself off after 30 mins. It gets too hot.
restore the factory optimal defaults in Bios...save changes and take a trial again ...if it is still the same ...go to screen savers and take a look at the power saving management and get them all out ...(its possible to have a cause here ) the last thing ...see how you can insert it a heat dispenser...or an extra external cooler...Probably it is the place where you keep and work it ....its too hot ..and it do not handle the heat ..
Its a good thing that the protection of the Cpu is working ..this is safe way to use it ...but its annoying when you are working something important and suddenly it remembers that its too hot and shuts down..:D
Jun 08, 2010 | Computers & Internet
E Machine T6534 fails every 6 to 9 months
This could be caused by the processor or fan,But very unlikely to be the mother board.
May 28, 2009 | eMachines T6534 PC Desktop
No pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
May 02, 2009 | Asrock K7S41GX Motherboard
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
Cylinder 4 misfire: lacks compression
the things that would cause lack of compression are:
  • bad headgasket
  • damaged piston rings
  • valves not sealing- could be exessive carbon build up, bad valve spring, bent valve
Oct 15, 2008 | 1998 Nissan Altima
Ihave a emachines modelT2792 and have een told the mother board is no good as well as the power supplycan i get another mother board for this computer or is it too old to fix it is about 2 years old
when all some other parts are good maybe you can replace the the mother board and the power supply.
you should find motherboard replacement that will fit to your processor and Memory.
if the memory , processor, hard drive are good, then you can contact your vendor if the have replacement(mother board) and power supply.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 15, 2008 | Computers & Internet
Dell Dimension 5100 (D51L1) PC Desktop Logo
76 people viewed this question
Alun Cox
