Question about Linksys Wireless-G WRT54GS Router (e125894)
I have a linksys WRT54g router set up to a desktop. I have 3 laptops on wireless - 2 laptops connect to the network just fine - but the 3rd laptop connects with limited connectivity. What can I do to get this 3rd laptop to connect to the internet?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 92 Answers
Double check that your router is not broadcasting in only G, make it reverse compatible. There is a chance that the other laptop may not be G compatible. Also check the security key and make sure it is correct. If your blocking connections by MAC address make sure the MAC of the non functioning computer is added. You may want to delete the current connection settings from the laptop and restart with a fresh wireless connection. I hope this helps. Good luck
Posted on Sep 25, 2009
Trying to connect to my laptop with windows 7. i have a Linksys Wireless-G WRT54G Router
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 13, 2011 | Linksys Wireless-G WRT54G Router
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Let me know if you need more assistance.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
Network/router problem
Is your router wep or wpa encrypted if so you need to put that wep key into your new laptop so you can connect to it.
Oct 17, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G can't connect 3rd wireless computer
log into the WRT54G wireless router and ensure that you do not have it set up for only handing out 4 IP addresses also check the laptop to see if it is set to have a DHCP or static IP address, if it has a static IP and your network is dynamic then this is why it wont connect.
if this resolves your issue and you are happy with the answer please grade me accordingly.
thanks
Aug 25, 2009 | Linksys Wireless-G WRT54GS Router...
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
Network has suddenly dissapeered
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Cannot access the internet
try this :
1. it seems that the power outrage had caused your wireless settings to be restored to its factory settings .... so there is a need to reconfigure it again ...
the settings that are saved to my computer do not match" --- this usually pertains to the network settings saved on your laptop, if it is vista you must delete the old profile,it also applies for xp OS ....
VISTA :
>network and sharing center
> manage wireless connections
>under networks you can view or modify, highlight the old profile then remove
XP :
>netowrk connections
> right click on wireless network connection and go to properties
>click on wireless tab
>under preferred networks (box in the middle) highlight then remove
2. to check this do ipconfig on the cmd line
•check the default gateway if it is still 192.168.1.1 or 2.1 ( the default gateway is the rtr's address)
•open your browser, then type the rtrs ip
• leave the username blank, password is admin ( small caps)
• then you are in the set up page
• check the wireless tab, and very the ssid if it is still or the name of your network which you used to connect to ...
• just save the settings if you want to make changes
****** very impt : while doing this changes, your main pc or dsktop pc must be hardwired to the router ,, never make changes wirelessly coz the connection is very instable you will be kicked of everytime ..... ***********
GOOD LUCK!!!!!
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Laptop could not detect linksys on second day
Jatman,
Couple of things you can try here:
1) Connect your laptop (or another computer if possible) to the router using a network cable. You should then be able to see your configuration info. Make sure that the computer you are using to connect (wired) to the router is set up to use DHCP. Once in there, depending on what you find, you might be able to fix it yourself.
2) Factory reset the router and go through the setup options as if it were brand new.
Hope this helps.
May 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
126 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
