Question about Toshiba N97842 13.3 TECRA M8-S8011 INTEL CORE 2 DUO T7100 1.8GHZ NOTEBOOK PC PC Notebook
Tecra m8 boot up problem
When I turn on the laptop the on light comes on but the forth light (HDD) does not come and the sceen does not light up. If I shut it down using the ON/OFF switch (held for 8-10 seconds) and try it again, sometimes it will start up and everything will be working. It can take several attempts.
    President:
  • 2,600 Answers
The true test here is, can it boot into the BIOS every time. If it can, then I suspect your getting ready to have a hard drive failure. Intermittent boot failures and non-start-ups are usually caused by a faulty hard drive. If it was your boot menu or boot loader, then it would never boot period. I would suspect the hard drive overheated and is damaged, or there are damaged sectors on the drive that contain some of your windows files.
Posted on Sep 25, 2009
Testimonial: "Yes, I also suspected the HDD only because the light for it usually comes on shortly after startup. Your explanation makes more sense."
Toshiba Tecra M1 what are hdd format procedure?
Formatting a laptop is the same as doing it on a desktop computer.
If you are using the Windows installation CD then to get the laptop to boot up with the Windows CD you can change the BIOS boot startup device and make the CD the first boot device.
Apr 24, 2012 | Toshiba Tecra M1 PC Laptops
Tecra A10 won't boot up. Laptop was dropped when running and froze. Shut it down to reboot but doesn't work at all. When the power button is pressed, the HDD LED illuminates for just over a second and then...
I suggest try going to Local Computer Centers, Have them check what hardware's are having problem, most likely there are problem with LCD, Motherboard, HDD.
Apr 21, 2011 | Toshiba Tecra A10 Notebook
Toshiba Tecra M3 will not boot, no video, pwr + hdd light on
If not beeps you didn't hear then it's your Motherboard. But, there other problems aside on it.
Laptop maybe have a problem with Power Connection, see to it that your Laptop Power Adapter is supply exact voltage to your Laptop, low voltage power also may cause not to give power your laptop sufficient, if it is does.
And if none of this then it's your Motherboard.
Hope this tip might help you.
Sep 23, 2009 | Toshiba (K000823110) Motherboard
I have a Toshiba Tecra M8 and the touchpad stopped working. I can still use a USB mouse, but i've tried the FN F9 key to make sure that the touchpad is enabled but it still isn't working. Are there drivers...
Check in the device manager and see if the touchpad is listed under pointing devices.If it is not there try add hardware and see if it detects the hardware. If it is there check to see if it says device is working properly. Sometimes touchpads require software to operate properly so check and see if software was uninstalled. You can also download the drivers/software from Toshiba, try removing the touchpad in the device manager and then re-booting the computer. When windows re-boots it should start installing new hardware found. Use the driver/software you downloaded from Toshiba. If none of these work your touchpad may be bad.
Sep 05, 2009 | Toshiba Tecra® M8-ST3093 PC Notebook
Replaced Toshiba HDD but won't boot from recovery CD
Put the disk in the drive and restart the machine, when the toshiba logo appears press F12 and use the cursor key to select CD/DVD and hit enter.
See if it lets you boot from the CD/DVD drive.
Please keep me informed and good luck.
May 29, 2009 | Toshiba Tecra TE-2100 Notebook
Toshiba laptop can't boot
Sounds to me like you may have a stuck key on the keyboard if its making sounds during bootup.
Could also be a problem with the hard drive if its staying on the toshiba startup screen.
Take the hard drive out of the unit and then turn on the laptop and see if it at least gets past the toshiba screen, if it does then turn off the laptop and put the hard drive back in. Turn the laptop back on and if it hangs then you know for sure at that point that the hard drive is bad and it will need to be replaced.
If you heard one beep after another and it doesn't stop then you know the keyboard is faulty. If you heard clanking sounds then you know the hard drive is bad that way as well.
May 04, 2009 | Toshiba Tecra A5 Notebook
HDD cange, boot error
is this the original hard drive
for boot options while in restart constantly press F7 a menu will come up high light your boot choice
you may need to run windows on the hard drive again
Jan 20, 2009 | Toshiba Tecra M2-S730 Notebook
Answer to your question
You will need to get into the bios, and set the CD drive to boot before the hard drive. Since your in this uncompromising loop, remove the hard drive, then start the machine. It should go to the initial Toshiba screen and you will see the prompt on what to press to get to the bios, or utility set up. Once your in the bios, find the boot order and set the CD drive over the hdd. Then put the hdd back in, the recovery or operating system disc in the CD drive, and start the machine. It should now boot from the disc. At this point you will want to do a system repair. If the repair doesn't take, then reformat the hdd, and install a new operating system. If the hdd will not format or you have any issues during or after the install, then the hdd has failed and will need replaced. If you need any futher aststance, just ask.
Aug 28, 2008 | Toshiba Tecra M1 PC Laptops
Toshiba N97842 13.3 TECRA M8-S8011 INTEL CORE 2 DUO T7100 1.8GHZ NOTEBOOK PC PC Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
