Question about Refrigerators
Original Post: Refrigerator- Kenmore Elite 795.77573600 Error "error if" appeared on display panel. I believe this is related to the ice maker fan. Unplugged freezer and turned ice maker off. Turned refrig. on, and error message does not come back. Error message reappears within 5 minutes if I turn ice maker back on. Refrig has been working without ice maker turned on for several weeks; however, the freezer has alot ice built up on the top and back of freezer. Do I need part number 1463582 (dc mtr.)? Also, does anyone have instructions and/or procedures for replacing necessary part? What I have done: I replaced the evaporator(freezer) fan motor Manufacturer part number 4681JK1004E/RepairClinic item number 1267574 and the main control board part number EBR34917104/RepairClinic item number 1463582. The main control board was definetely bad, because it contained a burnt transistor. The "error 1f" still displays ONLY IF the ice maker is turned on. If the ice maker is off, the refrif works fine. What else could be the problem? Thanks in advance.
  • 615 Answers
This error you are getting is coming from an issue with the fan you may call it freezer fan or evaporator fan, you stated that you change it however it still give you the same error that relate to the fan…first make sure when you connected all the parts that the ground is connected good as well as all connections. When placing the fan make sure it is moving freely and with easy. Do you hear the fan working when you start the ice maker? As a backup look inside the icemaker and see if you have anything that stuck inside…let me know
Please let me know how this worked for you and please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues
Posted on Sep 26, 2009
    Brigadier General:
  • Refrigerators Master
  • 3,614 Answers
This could be a loose power on the stove due to certain power outage happen earlier before the problem starts, the unit needs to be reset by plugging it out or you could turn the power off in you house via the circut breaker.
Hope this helps
  • 10,515 Answers
1F means you have an issue with your fan motor cooling your icemaker--- usually this means you need to replace the fan motor. Until you can replace your fan motor turn off the switch for the icemaker, then flip the circuit breaker to off for a few seconds and turn it back on. The display should remain lit and operable, but you won't have an icemaker.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 25, 2009
  • taran_2005
    taran_2005 Sep 25, 2009
    I would also like to inform you that this can be due to faulty electronic control board or leak in your dispenser!!
    If problem persists and you are unable to fix it, i would advise you to call a tech.
    Hope i helped you.
    President:
  • 1,714 Answers
First thing I would say is that it sounds like the defrost circuit is not working right. That's why you have ice built up in the freezer. There is a fuse in the defrost heater circuit you could check. The ice 'sensor' is probably bad. It monitors the temp of the ice forming tray until it reaches 19 degrees F, then it dumps the ice. It could also be the heater that comes on for 30 seconds to start the ice cubes melting a bit to drop. You can check both of these things I believe.
I would think that you'd get an error code though if the defrost didn't work. It doesn't sound right that there is ice built up in the freezer.
  • 15,935 Answers
The "Er-IF" in the display is caused by the Ice maker Ice Fan freezing up and not running or the Ice Fan is running but it's not being detected by the control board as running. Moisture has been known in some environments to migrate into the fan grill assembly and freeze and cause the ice maker fan motor to not be able to run and cause the "ER-IF" to display. This type of failure will require a service technician to repair your refrigerator. There is a proven fix to remedy the problem which will require a technician.
This involves a "re-flash" of the controller, and requires special equipment.
If everything is working as it should - it may not be worth the repair.
If there were burned components on the original board - there may be some suspect wiring as well.
Thanks for using FixYA!!
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore Elite Refrigerator Model 795.77563600. The front digital panel has an error code er if. I understand this means that I have a problem with the ice maker fan. Where is the fan located...
Jun 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
On my Kenmore Elite Bottom Freezer Refrigerator, the display on the left door reads ErCo and the ice maker does not work . Its less than 2 years old
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Er if code on display
ER means Error code......
The If error message indicates that the fan for the ice maker has failed. The main control board receives a feedback signal from this fan motor for the ice maker. If the feedback signal is abnormal or missing, then the error message will be displayed. The fan motor for the ice maker could be bad. You could also have a bad wiring connection between the motor and the control board. A remote possibility would be that the control board is bad. This is not likely since you noticed the ice melting in your storage bucket.
I recommend calling a service technician to diagnose and repair this failure.
Sep 20, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
H20 dispenser displays er lf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#
May 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore model 795 77563600 refrig side
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
DITIGAL ERROR DISPLAYING MESSAGE?
check your service manual and see what it say about err dh
Mar 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Control Pad displays Er CO.
Nov 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error Code Er FF
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
Jul 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
