I'm trying to set up an Asus P5SD2-FM motherboard. When I power up, all the fans start up and the memory and the video card are well seated in their respective sockets. The problem that I'm having is that I don't get any output to appear on the monitor. Any suggestions?? Help??
  • 742 Answers
Did you hear a "beep" sound? that beep represents a video being initialized successfully. Well, do you have an external video card? you must attach your monitor there if you have an external video card, the card you inserted for video like GeForce or NVidia
Posted on Sep 25, 2009
    President:
  • 1,865 Answers
Asus motherboards are garbage, I can only suggest that you get a different motherboard and do not buy any Asus products
I NEED A VIDEO CARD DRIVER FOR ASUS P5SD2-VM.
ASUS P5SD2-VM Drivers.
Visit the above link from ASUS Official Support. Select the Operating System (OS) and download the required drivers.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 19, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I am having motherboard P5SD2-VM motherboard having on board agp sis 3 mirage of 256 MB but it does not support to games like crazy taxi and even flash player programme which was working are not working...
Some games requires higher video card memory, you must look for the requirements for that game! I suggest if ur a GAMER, buy a HiGHER memory PCI video card! Taaah!
Nov 10, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Im having problem with this mobo P5SD2-VM. it dont run when press start button, no display and no beep also. the power is ok, the monitor is ok and cmos battery is ok. i have 10 of this mobo in our...
Check your motherboard memory card if it is still working. Remove it and then clean the pins of it using an eraser of a pencil. After it, place it back again to your motherboard and power on your computer. See if it works. Try also using a different memory card.
Nov 09, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My pc not excepted vga driver.
Have you turned the onboard video on or off in the bios off if your installing a video card or if your unsure check in the bios .Press delete on start up to get into the bios then go into integrated peripherals.If your unsure its in the Asus motherboard manual
support.asus.com/download/download.aspx?SLanguage=en-us
Aug 06, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Vga driver is not working properly
i have asus P5SD2-VM sis672/sis968 mother board.
but my graphic card driver is not working properly , when i download any game which is of having graphic card(128mb) min requirement it does not work properly.
what should i do for this .
Jul 29, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My ASUS P5SD2-VM Is Having A No Display Problem
Make sure you disabled th eonboard video card. Some boards do it for you automatically when you install a new one and others you must remove or switch a jumper pin on the motherboard. Consult your manual for the jumper location. Sometimes you have to use the default card and go into the bios set up and disable it in there, shut down the system install the card then restart using the new card. Make sure you use the first available PCI-e slot closest to the CPU and you should be all set.If not your card may be bad.
Joe
May 28, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Graphics problem
video card has too little memory to handle the game or is heating up!
May 12, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
If you are using the motherboards built in VGA graphic display, check your bios settings. Open your manual to page 2-22. Read the page.
Make sure you have the bios set to, Primary Graphics Adapter [PCI-E] set to, [IntVGA].
Set the internal VGA to, [Enable]. You will also need to set an amount of your system memory for the VGA to use. It is recommended if you are using Windows Vista that you increase your 1GB of system memory to, 2GB. Or instead you can buy a decent PCI-E video card that will use its own memory instead of your system memory. If you do this you'll need to change the bios settings to, Primary Graphics Adapter [PCI-E].
Also change, Share Memory Size to [Disabled].
If you need the manual for the Asus P5SD2-VM. Click on the link below;
http://support.asus.com/download/download.aspx?modelname=P5SD2-VM&SLanguage=en-us
Click the dropdown menu & click on your operating system. Than click Search. Asus list all drivers, manuals, FAQ's ect.
To view the manual you'll need Adobe Reader. You can download Adobe for free at this link;
http://www.adobe.com/products/reader/
Again, if you do not have any display & your using the built in VGA graphics card try resetting the bios. Doing this will reset the bios back to normal default settings. The bios will auto use the built in VGA. To clear the bios see page 1-22.
Mike
Apr 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
