Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Need a manual for sears model 139.18856, 1/2
Hi, i need a manual for sears model 139.18856, 1/2 hp chain drive garage door opener instalation instructions
    President:
  • 3,197 Answers
According to Sears your model number is bad. Double check the number and they will have the owners manual with complete installation instructions.
Posted on Sep 25, 2009
  • sam7308
    sam7308 Dec 10, 2012
    I have a Craftsman garage door opener model # 139.18856. I have looked all over the internet and there are a few people calming to have the same motor and people are telling them that they don't exist. I have attached a photo of this motor with model number to show that yes craftsman did make this at one time. Having said that, Im having a similar problem as this guy. When I press the button to close the door, the light blinks 10 times and stays on on the tenth blink. The output sensor stays green and the receiving sensor only flashes green when you put something in front of it, then move it away. I have cleaned both sensors, nothing is blocking it and the wire's look ok. If it is a sensor problem, can i use any sensors or do I need the sensors that came with this model that never existed. Thanks, Sam
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
How do I update software
Feb 03, 2016 | Kenwood DNX-690HD eXcelon DVD Receiver...
Garage door opener won't open or close door
The drive gear is stripped. Remove the cover and you can see it just in front of the motor. It is white nylon and the part number is 41A2817. Available from Sears or any good door opener service company. It will come with instructions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage door opener does not open or close
The drive gear is most likely stripped. It is a white nylon gear just in front of the motor. The parts number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Jun 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open
You can fix this by loosening the chain enough that you can lift it off the sprocket. Then run the opener until the sprocket turns counterclockwise and stops. Now with the door in the open position replace the chain. This will get the chain running the right direction. You will have to adjust the open and close limits along with the force adjustments but that will all be covered in your owners manual.
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
IS THE UNIT JAMMED AGAINST THE STOP BOLT ON THE RAIL??
IF IT IS THE CHAIN WILL NEED TO BE RESET RECHECK YOUR INSTRUCTION SHEET.
IF NOT DOWNLOAD THE INSTRUCTION MANUAL FOR YOUR OPERATOR AND GO THROUGH THE DIAGNOSTICS.
HOPE THIS HELPS
Mar 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener, chain adjustment
Loosen the inner nut on the trolley. (That is the lock nut). Then tighten the outer nut on the trolley to increase tension. The outer nut on the trolley is closest to the garage door. The chain tension should be 1/2 inch off the rail at midspan. (The chain is fastened to a threaded bolt on to the trolley. The threaded bolt has an inner and outer nut). Hope this helps.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,483 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
