Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Have a kv-34hs510 wega that will not come on. red light on standby flashes six times
  • 178 Answers
This is a common failure with this set, it is in the power supply, switch mode regulators in the ps need replaced, the repair would be typically cost around 200 - 250 from a shop to repair. if you want to fix it yourself i can get the part numbers just post back and let me know if you are a do-it-yourself er.
Posted on Sep 25, 2009
  • olivares1998 Apr 20, 2011
    Where can I get the part? how much does it cost?
Pressed power, heard the unit turn on, heard the tv show sound for a moment then it went into standby mode and the red light flashes six times, then pauses, six times then pauses, over and over and over. ...
Either your power supply is bad and needs replaced, or their is other circuitry issues. Bets to have a trained technician look at this and give you a quote for repair, it might be cheaper in the long run to replace the set.
Jan 18, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Tv will not turn on. red light blinks but nothing happens. sony wega kv30hs510
How many red flashes? Mine is flashing twice every 5 seconds and ended up getting a tv engineer to have a look. He has confirmed a faulty transformer approx. £120 to replace
Nov 23, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
My kv34hs510 will not power up and the standby light flashes 6 times and then repeats.What is wrong? Ron....
There is a power issue,tv goes into standby (safety) mode. For self-diagnostics, press Display,channel,5,volume - minus not plus,then press power. You have no horizontal output,check IC206,C516,C515....for service mode press Display,Channel,5,volume + plus,then power,press8,then enter......hope this helps....
Mar 08, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Trinitron won't turn on
this is the (OVP) over voltage protection,the unit goes into standby mode,there is a problem in power supply circuit,you need a ohm meter ,check T603 & R672.......you can get parts at Encompass Disturbution #1-800-638-3328 hope this helps.good luck
Feb 15, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony FD Trinitron WEGA KV-34HS510 34" TV won't turn on. Standby light blinks 7 times
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
Feb 20, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony trineton KV-34HS510
let me know how many times standby light flashes. this info will help me to assist you to resolve tv problem.
Sep 05, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
561 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
