Question about Alarm & Keyless Entry System Dodge Vehicles
My dodge caravan '09 keyless entry does not work at times
The keyless remote will not un lock the doors(both of them) until we open the door with the real key, Then every thing is fine. this has happened 3 times in 3 different places all of them with nothing in comnon
    Problem Solver:
  • 17 Answers
I've had the same problem with my 2009 Grand Caravan also.
I asked the dealer about it, but they weren't aware of anything regarding this. Since it has only happened a couple of times during the past year I haven't done anything else about it. They offered to replace the RKE fob (remote) if the problem persisted.
Posted on Mar 30, 2010
  • gmelander Jul 19, 2010
    The previous entry was not a solution, just an agreement on the problem. I too have had this happen twice in the 3 months that I've owned my '09 Caravan (purchased used). Would like to know the actual solution.
I have been having the same problem. The remote only works some of the time. I thought it was the battery but I have replaced it and it is still the same. Very frustrating!
Posted on Aug 28, 2010
Need wiring diagram for 2005 dodge caravan sxt model door locks will not lock
This is with Remote Keyless Entry System...I have one without keyless entry also....
Jul 25, 2011 | Dodge Caravan Cars & Trucks
I went to install an audiovox as-9076 in a 2003 dodge ram 4 door and couldnt get it to work with the factory keypad...the wiring diogram gave me different wire colors...i know im supposed to us the...
Ya have to trace them out with a test light...! Pin the wires with the light and hit the lock un lock control untill you get the wires you need ZI seriously dought you need 3 where did you come up with 3 wires did you lose sa door in an accident???? Usualy if you hit the un lock once it opens the drivers door and twice opens ALL DOORS.. your power will be 12v battery probaly the first wire ya hooked up
t
h
e
n
a
l
l
a
h
h
h
Jul 16, 2010 | Car AS9076 Upgrade Remote Start to Keyless...
Doors lock themselves
Sounds like the keyless entry system is malfunctioning. Remove the door lock relay for now until the dealer can reprogram it.
Jun 14, 2010 | 1998 Dodge Caravan
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
Jun 05, 2010 | 1997 Ford Windstar
Can't program Second remote to my Ford Explorer 99
reading your post you mention to "open and close switch"..not sure what refering to...these are the instructions from your vehicles service manual...good luck!
Programming NOTE: All keyless entry remote transmitters (15K601) are programmable and must be set at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Diagnosis and Testing.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
Jun 08, 2009 | 1993 Ford Explorer Limited
02 Dodge Caravan Locks wont unlock
I would check the obviouse first, That would be the battery in the remote. You can replace them from a radio shack store. Next find out the make of the keyless remote and email the manufacturer or call them. In fact thats how i solved my remote problem. There are also discount outfits on the net that will sell you another remote. You must give them the make and model and vin.
May 13, 2009 | 2002 Dodge Caravan
1996 Dodge Caravan door locks
does it have after market alarm or remote start/ keyless entry system in it? if so that is at fault
Jan 30, 2009 | 2005 Dodge Caravan
Keyless Entry and Remote
I have had this problem take you drivers door put your key and un-lock from the out side with key (NO) then open the door push un-lock from the inside button and then set from you remote and it should set if not push un-lock then lock and then do the un-lock with the key. Let me know if that works. what my car did was locked from the inside and I had the problem were it would not work till I un-locked from the out side plus I had to go to radio shack and change the battery from the control.
Hope good happens.
Nikki2913
Oct 22, 2008 | 1996 Ford Explorer
2008 dodge caravan se minivan
hit menu on your message center and cycle through choices, press step to pick option
Aug 15, 2008 | 2007 Dodge Caravan SXT Minivan New Cars
Alarm & Keyless Entry System Dodge Vehicles Logo
1,249 people viewed this question
Top SMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a SMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
