I purchased the laptop(Pavilion dv2000) in Jan. 08.This evening, I closed my laptop without turning it off, but 20 minutes later, when I opened it, it was black screen. I turned it off and turned on again.The computer is running, but it was still black screen.the computer is running. What should I do?
    President:
  • 1,187 Answers
This is a common hibernation issue ... here is the fix:
Once you are able to get it to start up again (there is no sure fire way to do this, it just happens!).
The virtual memory size is set too low! It must be set to an amount larger than your amount of physical memory. (If you have 2GB or memory, then Virtual memory must be more than 2048MB.
Right-click [My computer]
In the [General] tab, note the amount of RAM
Select the [Advanced] tab
Select the [Settings] button in the "Performance" section.
Click on the [Advanced] tab
Click on the [change] button in the "Virtual Memory" section
almost there!
Highlight the boot drive (C:)
Don't change the locartion of the VM file.
Select "Custom size" radial button.
Enter a number that ois larger than your physical memory from the General tab
1GB = 1024MB (plus 512MM or so) = 1536MB
2GB=2048MB (plus 512MB or so) = 2560MB
3GB=3072MB (plus 512MB or so) = 3584MB
[SET]
[OK]
[OK]
etc.....
Posted on Sep 25, 2009
    President:
  • 2,600 Answers
Reboot the computer and when you here the motherboard tone, tap the delete key to see if you can get into the BIOS screen. If the delete key does not work, try F2. If you can get into the BIOS, then there is a chance it is simply a case of a bad setting. Go to the system default...which is probably on the last page of the BIOS screen. Click set default settings and then F10 to save and reboot. Try letting the laptop boot normally. If it does great, if it doesn't, try tapping F8 on a reboot after the sound and see if you can get into the multi-boot menu. If you can see the menu, boot into safe mode with networking. If it does boot into safe mode, try to update the video driver. Go to control panel > device manager > scroll down to video adapters and right click on the adapter listed and update driver. After it is finished, try to reboot normally.
Where is the lid close swith located when looking directly at the hp pavilion laptop dv2000?
Not sure on that model but if it has a visible switch it's near to or underneath the hinges, the right one usually.
Feb 08, 2012 | HP Pavilion dv2000 Series Laptop Full...
My HP Pavillion dv2000 laptop had windows ultimate 7 installed on it on 10/26/09. On Jan 15,, 2010, a reboot disk was inserted into my computer by a friend. I later found out that it was for a dell with...
You can order a set of recovery disks from Hp and reisntall all the drivers and Windows 7 on the computer.
The disk should not cost more than $20.
Call 1800-474-6836
Jul 20, 2010 | Computers & Internet
How to find out what laptop screens are compatible with the hp pavilion dv2000 to replace my cracked screen
Purchase the Genuine parts. If you put any other laptops Screen, it might create problem later.
May 04, 2010 | HP Pavilion DV2700T PC Notebook
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Pavilion DV2000 no Display
First pull motherbord from cabinet some times motherboard is grounding with cabienet.
Then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reconnect ATX power connector to motherboard.
Then check.
If still same issue then open processor fan and processor then clean dust from all place in mothebord.
Then try.
If you still got same then something rong with your ram or motherbord.
Change ram then try.
Pull all card from PCI slot check motherbord only with RAM not even harddisk and other device.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Pavilion dv2000 overheating problem
did you make sure that the fan is running? also alot of people run their laptops on the bed. thats a no no. the computer does not get air and it can damage the cpu
Mar 27, 2009 | HP Pavilion dv2000t Notebook
HP Pavilion DV2000 running very slowly
Yes! I would not recommend anything below 2GB at minimum. I have one laptop with 2GB and one with 3GB: they both open programs and browse the internet very quickly. Even with just two programs open (Internet Explorer and Outlook 2007) it uses 1.1GB of memory.
Definitely upgrade your memory. I recommend this site:
http://www.4allmemory.com/
Just pick your model and they recommend the memory to pruchase. TIP: order with next day shipping - it's only $10. The free shipping takes 14 days. So unless you're patient (I'm not) the $10 many be worth it.
May 29, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion DV2000
first replace the inverter to correct the lighting problem ok. then move to the other problem both can be recovered from
so ebay dv2000 lcd inverter buy it get a screw driver link me bakerandre2000@yahoo.com
Apr 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
