Question about Roadmaster (VR500CSBT)
No sound everything works fine. VRCD400-SDU - Roadmaster (VR500CSBT)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 92 Answers
If you are sure that everything is hooked up correct and have no sound, you most likely have a bad speaker that caused the final amplifier to go out. These are two chips mounted inside the radio towards the rear. they are connected to a large heat-sink to distribute heat. If your savy enough you can replace them yourself, otherwise you will need to take it to a shop. This is a comon problem and not a very expensive fix. Before replacing the deck back in the vehicle, be sure your speakers are checked and read at least 4 ohms each.
Posted on Sep 25, 2009
VRCD400-SDU VR3 stereo wont make a sound all works fine and when I take it off it makes a ''turf'' sound. what can I do?
wired in my VR3 stereo and can not get any sound through my speakers just the subs will work also it says seek TP/TA any solutions to my problem or any suggestions?
Sep 25, 2009 | Car Audio & Video
Vrcd400-sdu
top row, left to right;
ground,memory,panel light,rear left spkr -,f rt spkr-, f lt spkr -, empty.
bottom row;
ylw batt +, red batt +, empty, rrspkr +,rlspkr +,frspkr +,flspkr +, empty.
Sep 17, 2009 | Cars & Trucks
I have a VRCD400-SDU displays and modes but no sound.
The radio's output amplifier has failed.
Most of the time this is due to a blown speaker.
Repair is not recommended - as it exceeds the replacement value of the radio.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Aug 19, 2009 | Roadmaster (VR500CSBT)
Change the clock setting from Europe to America on VRCD400-SDU
under the faceplate is a small switch. there is an "A" and a "B" move it to "A" for american.
Feb 01, 2009 | Roadmaster (VR500CSBT)
My vrcd400-sdu will not trn on...
i have a vrcd400-sdu the reset reset led it go on and off the radio well not come on
Jan 20, 2009 | Virtual Reality VRCD500-SDU CD Player
NO SOUND AFTER INSTALLING VRCD400-SDU
I had the same problem and all I did was buy new wires the ones that came with the stereo itself burned up and seased to work. now I paid $6.00 for it at best buy. they look the same colored wires as the ones that came in it.
Dec 29, 2008 | Roadmaster (VR500CSBT)
Vrcd400-sdu car stereo
email the maker of the unit and ask for one
Nov 09, 2008 | Jensen 100W x 4 Amplifier KA5 Car Audio...
No sound...
Hi XX,
Let's try the easy ones first:
1. try to do a reset of the unit;
2. check that all the speaker wirings are:
2.1 connected properly following the wiring diagram;
2.2 not bare/exposed and touching any metal part/chassis;
3. verify that the MUTE is not enabled;
4. try all signal sources: AM/FM, CD, SD Card, USB, AUX;
5. verify that the SEL is set to SUB OFF;
6. replace the CR-2025 Lithium battery of the remote.
If your concern has not been corrected after completion of the above procedures, you may need to:
a. open the unit for a loose connection and/or other diagnosis;
b. ask assistance from the manufacturer's Technical Service at 1-800-445-1797;
c. return the unit for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 02, 2008 | Virtual Reality VRCD500-SDU CD Player
NO SOUND!!!
check all your fuses and then take the face plate off and push the reset button. if that doesnt work just check the wire connections sometimes if the wires dont have enough contact they want work. i had that issue when i upgraded the speakers in my jeep the connections were not good enough.
Vrcd400-sdu error code 13
CD will not go in dis slot
Jan 02, 2008 | Car Audio & Video
Roadmaster (VR500CSBT) Logo
327 people viewed this question
Top Roadmaster Car Audio & Video Experts
xxxxxx xxx
Are you a Roadmaster Car Audio and Video Expert? Answer questions, earn points and help others
