Question about Prima C2012 TV
Turning parental control blocks off
I have a tv/dvd combo unit. Somehow it is set to block out pg rated movies or telivision shows. How can I take this block off??
    Brigadier General:
  • 4,090 Answers
Parental locks are put in place to stop minors from accessing usuitable programs. An adult usually selects the channels to lock out as well as categories of videos that can be played. Thesae are controlled by a code neterd by the Parent or Giuardian and cannot be subverted without knowing the code. I am tempted to say.... ask your parents for permission to unlock this. We cannot supply any information without proof of age here.
With this model also there are no secret codes listed to over ride an entered password as its not a regular brand of TV. maybe the people you bought it from ( Walmart?) may be able to contact the supplier who rebadged this unit, to help you overcome the problem
Sorry we cant be of more help for you. Please accept our apologies
Thank you for using FIXYA
Posted on Sep 25, 2009
Hi my TV says input blocked when I set my DVDs player up to it! I don't know the password can someone help plz thanks
It sounds like maybe a "parental control" issue set on the TV. Can you try playing a DVD with a "G" or "PG" rating maybe? Also, if it is a factory set password, try "0000" or something simple like that.
May 30, 2016 | Televison & Video
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Unable to get some NR movies to play even though I have unblocked NR material
The parental code is :
1,2,3,4
When the parental block comes up hit play, then type in the code and hit play again.  It should be all set.
Mar 28, 2008 | Disney Princess TV/DVD Combo
Parental block princess dvd
This will make the player region free which may also reveal a menue that either gives you the oppertunity to clear the password or clears it automatically...
1. Turn on the Player (with no discs in)
2. Press the Open/Close button (leave it open, like if you were yet to insert a
DVD)
3. Press the Display button (on the bottom of your remote control, close to the
numbers 0-9)
4. Press the following sequence: 1,3,6,9.
5. Press the number of the Region you want (0 for Region free)
6. Turn off and on your player.
Dec 12, 2007 | Televison & Video
Soundstorm car dvd player
This is from the soundstorm website: If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308. Once you have this code, you can go into the settings and change the level to whichever level you like. Here is a break down of the levels: Level 1 = G Rated Level 3 = PG Rated Level 4 = PG 13 Rated Level 6 = PG-R Rated Level 7 = NC-17 Level 8 = Adult Level 0 = No Parental
May 29, 2007 | Soundstorm SDVD-100 Car DVD Player
Message protected program by tv-pg
Go into Menu /V Chip arrow key up to tv rating should show all locked volume down or visversa should should view all Note may have to volume up to get to options from menu depending on how old the tv is.
Apr 04, 2007 | Emerson EWV403 VHS VCR
Prima C2012 TV Logo
222 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
