Question about Toshiba TN55X81 55" Rear Projection Television
How do I get into the tech convergance of my
How do I get into the tech convergance of my Toshiba Tn55x81. I had a tv repair tech out and he got into a screen that had a convergance line about eevery inch across the screen like a checker board. I saw him get into it from the front of the tv but I don't know what he did to get into it.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Here are my own instructions----WHATEVER YOU DO DO NOT ATTEMPT TO ADJUST THE GREEN!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Toshiba entry to adjust
With the set on press MUTE on the remote.
Then press and HOLD mute for several seconds and while still holding it on the remote press Menu on the front of the set.
A (S) should appear in the upper right corner of the screen. (It means you are in the Service mode)
Press menu again on the front of the set
7 on the remote will call up the convergence grid
3 on the remote will change the color to adjust from red to green to blue(do not adjust GREEN)
You navigate the grid with 2, 4, 6, and 8 buttons.
To stop the cursor from blinking so you can adjust at any point use the 5 button—to move again use the 5 button.
When you finish you exit by hitting 7 on the remote again.
Sometimes you have to try a few times to get into the menu—I have had my problems but once in it is easy.
Let me know if this information was helpful and if you have ANY questions or need advice let me know.
SD TECH
Posted on Sep 25, 2009
The video on ours keeps distorting by 'crunching in' from the sides randomly. Any thoughts??
Ur tv have a problem call convergence,it dead.The convergence board require 2 STK convergence ICS and some or all it resistors to be replaced to solved convergence problems.U know how to do soldering?Have soldering iron,tools and solders?Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 28, 2010 | Toshiba TN55X81 55" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
My toshiba tn55x81 is getting lines in the screen. nothing major but the main problem is that it is losing its color focus after about 5 minutes of being on. i did adjust the color convergence and it did...
the prism is off balance or some bulb burning out, and you might need to replace parts. this would require a tv repairman, it is not an easy thing to do, looking at 200 to 400 repair.
Oct 17, 2009 | Toshiba TN55X81 55" Rear Projection...
I have a Toshiba TN55X81 that has sound but no picture. Turned it one one day and no picture. I don't see any error code blink when I power on the set.When the set is turned off a line flashes across the...
It shouldn't be the convergence chips. You may have blown a pico fuse on the power board.
You should be able to safely remove the convergence IC's and try the tv without them as they only do image correction.
Oct 13, 2009 | Toshiba TN55X81 55" Rear Projection...
Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Jun 15, 2008 | Toshiba TN55X81 55" Rear Projection...
Blue convergence
They should be STK392-110 ICs you can get replacement ICs at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Jun 04, 2008 | Toshiba TN55X81 55" Rear Projection...
Toshiba TN55X81 screen shifted
horizonntal circuit seems not to be working
May 26, 2008 | Toshiba 51H84 51" Rear Projection...
Toshiba TN55X81
Blue Convergence IC is bad = change both for reliable repair..
located on largest heatsink on chassis.............T.
Feb 02, 2008 | Toshiba TN55X81 55" Rear Projection...
TN55X81 Rear Projection color separation - convergence problem
You shouldn't need to do a board replacement, all you should need to do is manually tune the convergence.
You can do this with the built-in user tool, but there's also a far more powerful set of options in the service mode. To save you the trouble (I advise doing a LOT of reading before attempting any of this) here's a solid set of various tutorials based on what form of "separation" you have occurring:
http://www.keohi.com/keohiHDTV/brandspecific/toshiba/servicemenu/servicemenu.html
Nov 21, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba TN55X81 55" Rear Projection Television Logo
267 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
