Question about Linksys Wireless-G WRT54G Router (DSLSWRT54G)
Windows vista I'm having a hard time getting my new laptop with windows vista to connect with my new linksys wireless router...it recognizes the linksys but fail when i try to connect
  • jsginez Apr 27, 2008
    my new vista desktop will recognize my linksys Wireless-G WRT54G Router but will not connect to it.
  • ambrosiom Aug 12, 2008
    I do not know if I can explain this right . Ater a lightning, last week, I lost all my communication with DSL,Internet, everything come 0 I did call the tech.
    and intenet is ok but not my wireless laptop Pc Win. Vista .I have the password, but maybe I do not fixed the connetions right. the lights are ok, but I lost connection .What can you do?
    My Fax is 9545687664, in case you show me the desines connetion.
    Best
    Mary
  • 556 Answers
Setting up routers is best when done one step at a time.
Has anyone connected successfully directly to the internet service providers hardware using a wired connection, if possible?
Is the router connected through the internet service providers hardware or does it replace the internet service providers hardware?
Before dealing with the wireless has any computer connected successfully to the internet using a wired connection THROUGH THE LINKSYS ROUTER? They will not have to stay that way but a test without the wireless is less complicated.
When all the above is successful it is time to test the wireless, preferably first unencrypted for a short time and later probably encrypted in the final solution.
Does all the above sound like a reasonable step by step approach? If so let's continue --
First let me know how far we have successfully tested in the step by step tests by answering the above.
In planning for wireless access see this response and consider how much assistance you may require
See http://www.fixya.com/support/t301418-encryption_off
Then I will provide instructions to the level you require.
There are some skills you will need as we go along so here are some tests you can attempt
Perform the following steps on a wired and a wireless computer -- this will yield useful information and record the answer.
This assumes Windows XP (probably Win2000 and maybe Vista)
Click Start select all All Programs select Accessories and click on Command Prompt
In the open window type
ipconfig /all
Record the adapter, IPaddress, subnet mask, default gateway and DNS addresses for each adapter (there may be more than one and report them here for each machine.
then you will ping the default gateway address that probably starts with 192.168.?.? to do this in the open window type
Ping (default gateway)
It works when a line comes back with elapsed time generally in ms or milliseconds -- it fails when you recieve a timeout message these normally occur in a block of 4.
If you get stuck provide me the answers you have determined and tell me what went wrong and we will start again from there. OK?
Posted on Dec 16, 2007
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
Jan 03, 2010 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
I cannot make a wireless connection my new laptop to the linksys router. My homenetwork works and my first laptop is connected to a wireless linksys connection. when adding another laptop I cannot make a...
then it's the second computer's problem, try repairing the connection, turning the wireless switch on and off, rebooting, and if your using vista use windows system file checker
or if xp, put this in either command prompt or run
chkdsk /r
Sep 30, 2009 | Linksys Wireless-G WRT54GS Router...
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless B Router Compatible with Windows Vista?
I would advise you to purchase a Linksys G router, Model # WRT54G2. Works well with Vista and your other laptops will work also.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 26, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Toshiba Satellie P305D Wireless Connection Issue
If you are having an issue with your wireless at home, try changing the security settings on your router i.e changing the password, or encryption type.
Mar 16, 2009 | Computers & Internet
Connecting wireless router to my laptop
you have to open up the wireless menu on the laptop and have connect to the linksys, which will be your router and it will ask for a code and that code is on the back of the router and you will connect as soon as you put that code on there
Jan 31, 2009 | Linksys Wireless-G Broadband Router
My local area network will not recognize my new laptop
You will find that the laptop has it;s firewall turned on. Temporarily disable it (assuming that your router firewall is enabled) and it will work.
Dec 11, 2008 | Linksys Wireless-G WRT54G Router
Wireless problems with windows vista
You just need to remove the preferred networks on your vista, follow this.
Right click the wireless icon>network and sharing center>manage wireless network>remove all preferred networks.click OK.
Then connect again to your network that should solve it.
Jun 13, 2008 | Linksys Wireless-G Broadband Router
Loss of Connectivity
Libog1 - did you install any additional wireless software to connect to the router (Linksys software) or are you just allowing Vista to connect directly using Windows' built-in wireless management?
Ben
Mar 03, 2008 | Linksys Wireless-G WRT54G Router
I can't get my new Vista computer to connect to my wireless network
I experienced a similar problem with a Vista laptop a few weeks ago. There were no apparent problems, so I uninstalled the wireless network adapter from the Windows "device manager" and then let it automatically reinstall the wireless adapter when it rebooted. The local wireless network appeared about 5 minutes after the reboot and has been working ever since.
If that doesn't help, try removing the Linksys software from your computer and try the network adapter remove/reinstall again.
Jan 10, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router (DSLSWRT54G) Logo
78 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
