Question about Sony VGC-LT16E VAIO 22" All-in-One Desktop PC
Wont power on
How can I open the back cover of VGCLT20E? What screw should be removed to open the back cover?
  • 69 Answers
There should be little screws on the back in holes
Posted on Sep 25, 2009
How to Replace a Gateway PC power supply
Just open the cover, find the four screws in the back of the computer that hold the power supply, remove those screws, unplug all the cables making note of what goes where and what needs to be pluged in. replace the power supply, plug all the cables like before and screw the four screws back, replace cover and you should be done.
Jun 08, 2014 | Gateway 550GR PC Desktop
Bosch dryer wtmc3300 was overheating and now wont start up. Only makes a clicking noise. The time indicator lights up and thats it.
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Dec 01, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
It wont print and everytime i try to print it says error #1200
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
How do i get back inside door cover off
This will be the same for the back even though it is for the front door....you just don't have the master switch...and a tool that looks like a flat tip screwdriver with a slot in it will help to remove the door panel without you breaking off the tabs that secure the panel to the door. You can get it at any auto parts store for about $6.00:
  1. Open the front door glass so that the distance from the top of the front door glass to the upper part of the front beltline molding is 8.3 inch (210mm).
  2. Disconnect the negative battery cable.
  3. Open the inner handle cap using a small screwdriver, then remove the screw.
  4. Remove the inner handle cover.
  5. Disconnect the door lock switch connector.
  6. Remove the inner garnish.
  7. Remove the cover, then remove the screw.
  8. Remove the lens cover, then remove screw.
  9. Disengage the clips from the front door using a fastener remover.
  10. Pull the front door trim upward, then disengage the tabs from the front door.
  11. Disconnect the power door mirror switch connector and the power window main switch connector.
  12. Remove the courtesy light.
  13. Remove the front door trim.
  14. Remove the switch panel from the front door trim
  15. Remove the hole cover.
  16. Remove the screws.
Aug 30, 2009 | 2005 Mazda 6
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
Fuser replacement
Wow i've worked on old printers but this is the the cream.
1-Open back door and remove the back cover ( two screws)
2-remove the top cover.
3- remove the cleaning pad cover and the pad,
4-take out two screws that hold fuser,
5-unplug fuser (two plugs, power and sensor plug)
6-remove fuser
Aug 07, 2008 | Lexmark Optra S 1855 Laser Printer
Removal of cooling fan
You need to disable your laptop.
follow this step:
Remove harddrive.
1. on the back of laptop, there are 2 doors. open it all. 1 of them is harddrive.
2. remove harddrive.
Remove wireless cable.
1. open 2nd door on the back, you can see rams and wireless card. unplug wireless cable from wireless card.
Remove chassis
1. Remove 2 screws on the hinge cover, so you can remove the power cover (power cover is cover that have power button).
2. after you removed power cover, removed keyboard.
3. remove 4 screws that hold lcd from chasiss. you can remove lcd now.
4. remove 3 screws under keyboard.
5. remove all screw on the back of your laptop.
6. remove upperchassis.
7. remove 2 screw that hold motherboard from lowerchasis.
8. take motherboard out from lowerchasiss.
9. now you can see the thermal fan.
Jun 19, 2008 | Acer Aspire 5050-3242 Notebook
Right-click button has collapst on bottom side. have to click at top of button
To disable Aspire 5100.
1. remove battery, harddrive.
2. open all cover on the back of laptop.
3. removed wireless antena cable from wireless card.
4. remove power cover (power cover is cover that have power button)
5. removed 2 screws on the back that hold lcd.
6. removed 4 screws that hold lcd. (now you can remove lcd).
7. remove 2 screws on top that hold uppercase from lowercase.
8. remove all screw on the back.
9. remove heat sink, and remove 1 screw under heat sink.
10. that's all, you can remove uppercase and repair it.
i hope this help you. good luck
Mar 22, 2008 | Acer Aspire 5100 Notebook
Remove back panel
You have to remove the base at the bottom (4 screws), all the screws on the back, then use a thin flat-head screwdriver or other thin brybar and work around the back panel unlatching the snaps that are in place.
After the back cover is off, the metal cover over the board and power supply can be removed by removing the screws around the outside lip of the cover, along with the screws on the bottom and right hand lip of the raised area in the back.
Hope this helps.
Dec 06, 2007 | ViewSonic N3251w 32 in. LCD HDTV
Help me
Hi Beth,
You need to take it apart, and get  everything back in its place.
REmove  8 or 10 Screw covers on bottom of your PS2.  open the case carefully, so as not to pull a cable loose from the motherboard. The Cd player cover needs to be removed to get your CD out. Remove 2 or 4 screws to gain access.  You could actually do this in less than 30 minutes. Go for it Beth
Oct 21, 2007 | Sony PlayStation 2 (PS2) Console
Sony VGC-LT16E VAIO 22" All-in-One Desktop PC Logo
69 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
