Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
I want to know the wattage for Hitachi 43fdx11b
    Sniper:
  • 92 Answers
225.0 Watts. power consumption, if you need further info please let me know. More info can be found at the following web site. I hope this helps.
http://reviews.cnet.com/projection-tvs/hitachi-43fdx11b/1707-6484_7-7248010.html
Posted on Sep 25, 2009
  • 178 Answers
225 normal up to 265 watts for high brightness scenes.
When the set is off it draws 2.7 watts
2 Suggested Answers
SOURCE: Hitachi Model # 43FDX11B. Will not power
Mine just developed the same problem.. did you find a solution/fix?
Posted on Aug 09, 2009
I have the Hitachi Model # 43FDX11B Date Oct. 2001, I can not get the TV to turn on when I turn then power on. The only thing it does is flash a red light down by the power button. What do I need to do to...
hello, the red light is flashing because theres a fault with the tv count how many times the light flashes the this gives you an error code then do a search on google or get back to me i'll try and tell you the fault and possible fix
regards
shaun
Nov 24, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi rear projection TV Model 43FDX11B with convergence problem
You will need to install a convergence repair kit. You can get the repair kits with instructions at www.tvrepairworld.com
Sep 21, 2010 | Hitachi Televison & Video
Wattage
1 watt,Service Manual I have says RK42 3.3ohms RK46 1.8ohms RK50 2.7 RK54 1.5 RK58 3.9 RK62 2.2
Dec 30, 2009 | Hitachi 50FX20B 50" Rear Projection...
Green wave on left top and center top in my 43FDX11B TV
replaced both convergence ics in the tv.also check for open resistors near the convergence stk ics.
Jul 17, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Jul 09, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 43fdx11b green wave on top left and center
Its likely that you did not find all the resistors that were damaged when the original failure occurred. Now you must re-replace the ICs and locate the other damaged resistors. Check all, including those you just replaced. Use a good ohm meter and be certain that all the resistors are gold band tolerant(5%) and of the exact resistance value and wattage.
michtech
Feb 15, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Stk392-120 hitachi 43fdx11b
Stk392-110,-120 and -150 are replaced with upgrade IC's....
Stk394-160E = use kit # X 480293 ( has two in kit = replace both)...................T.
Apr 21, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43fdx11b rear proj tv
you can check at vancebaldwin.com or ctechnicians.com
Jan 04, 2008 | Televison & Video
Hitachi 43FDX11B television Ghosting
I had the same problem on my Hitachi rear projection TV 53FDX20B made in Mexico. The blue convergence problem. Blue focus had shifted and appeared like a blue ghost image. I followed the step by step intructions from the fixya site. First Replaced the two STK 392-110 ICs and turned on the tv. No change. Then I went looking for the bad resistor. There was one resistor RK50 (2.7 ohm, 1Watt capacity) which is attached not right close to the printed circuit board surface but was well raised up from the board. The bands on the resistor were a little discolored. I replaced that one and turned on the tv. The convergence problem was solved. Thanks for the step by step instrucitons on your site.
Dec 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
