Question about Canon Rebel XT / EOS 350D Digital Camera
Canon Camera - DS6041 wont turn on?? Saying err after afew mins of being turned on... Tryed new battery... Have no idea what went wrong?? Where in auckland can i take it to fix it??
5 Suggested Answers
SOURCE: digital rebel EOS ds6041
This happens when image data cannot be written/extracted on CF card. Try a card that you know is ok ( works on other cameras ). If problem persists one or more pins in the CF card chamber may be bent or even broken off. Try to straighten but be careful not to damage undamaged pins... but may have to go to an expert for repairs.
Posted on Sep 13, 2007
poolseman
  • 206 Answers
SOURCE: canon ds6041
The error 02 can come up when there is CF card problem : card not seated properly , card takes too long to come on line from the cameras point of view or if one of the the pins inside CF card chamber is faulty.
Posted on Sep 16, 2007
  • 155 Answers
SOURCE: canon rebel eos ds6041
DS6041 is the model number for Canon EOS Digital Rebel or 300D. It is a 6.3 megapixels DSLR camera from Canon.
All software and manuals available from the Canon site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=9430
Posted on Feb 18, 2009
  • 11967 Answers
SOURCE: canon eos ds6041 the mirror went
You aren't seriously considering gluing the mirror back? Your camera requires expert service if you ever expect it to work properly again.
Posted on Oct 20, 2010
My canon ds6041 displays err 99 when i try to capture light aur object in sun light.What should i do i'm using 70-21-mm lense
Usually this is cased by shutter failure or failure of the aperture unit in the lens. Try another lens and see if you get the same error message - that will tell you if the problem is in the camera body or lens
Apr 05, 2013 | Canon Digital Rebel / EOS-300D Digital...
The camera say,s , err 02
Err 02
Description: The camera cannot access the memory card.
Resolution:
  1. Remove and re-install the memory card.
  2. Format the memory card as described in the user manual. The user manual for your EOS camera can be downloaded form the Canon Europe EOS camera support page.
  3. If formatting the memory card does not resolve the error please replace the memory card.
Dec 27, 2012 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
May 25, 2009 | Canon Cameras
ERR 99
try cleaning the battery contacts and the contact spring tabs in the battery compartment... also visually check to make sure the tabs are sticking out to make good contact with the battery terminals.
Also here's an excerpt from a canon blog ..it's a quote from a Canon usa service guy...
hope it's a help for you..
One of our participants in the long comment thread below (Tom) got this in a message from Canon USA. It may help some of you isolate the problem before you post a comment/question.
To isolate the cause of the issue, we suggest that you do the following:
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
May 25, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Err 99 appears after every click for canon eos 30 D
Err 99, but lens-to-body problems are common- thought error 99 is a bit of a catch all- generally a lens and body conflict. And also Err 99 means that something wrong happened, but then it cleared out before it could be further determined.
Here is the blurb from canon to try:
following:
steps:
camera body.
For factory service, forward your digital camera (remove the CF card
and battery) properly packaged and insured, with a letter describing the
difficulties. Be sure to include your name, address, telephone number,
and proof of warranty (if applicable). Send to the Canon Factory
Service Center at the following address:
Canon Factory Service Center
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
Tel.# (949) 753-4200
Your equipment will be examined and you will be advised of the
findings.
The length of time for the repair will be dependent upon the nature of
the repair and availability of parts if needed. If the repair entails
something that is not covered in warranty you will be sent a written
estimate to the address that you have provided.
Please leave for me, a rating...
May 15, 2009 | Canon MF8180C Color Laser MFC Printer
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon Rebel XT EOS Every time i take a pic I get an Err 99. I have taken the battery out and memory card for 5 Min. If i do that I can take about 5 or 6 pics before I get that message again. What...
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
214 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
