NEC Versa VX PC Notebook
Problem for NEC Versa VX PC Notebook
Laptop will not operate or charge the battery from
By kiwi_memorie on Sep 25, 2009
Laptop will not operate or charge the battery from the power pack. It runs fine on battery.???? It is an NEC Versa M400
Comments:
Sep 25, 2009
- This is definately a laptop fault, as I have an identical machine that operates fine from the power pack. There appears to be a short between the positive pins and earth at the power socket on the laptop.
Solution #1
posted on Sep 25, 2009
Somewhat Helpful)
Gort007
Rank: Guru  Computer Hardware  Expert
Rating: 89%, 488 votes
1. Power OFF laptop
2. Remove battery
3. Use power pack and turn ON laptop (without battery)
4. The laptop will work.
5. After Windows has settled down, insert battery (with laptop on and Windows running).
6. Allow the power pack to catch up a couple of hours.
7. It will work now...
Comments:
Sep 25, 2009
- Kiwi,
Thanks for the comment and more info regarding the issue.
Yup, follow parrothead's solution.....
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
parrotheadpc
Rating: 89%, 594 votes
Your power pack has a voltage regulator built into it to maintain and controlled and steady correct voltage. These devices are usually under a great deal of stress and fail often. The thing to remember about power supplies for laptops is you get what you pay for. The PSUs that are coming from overseas will power your laptop but they get very hot, fail frequently and in most cases will not give you a reliable stable power supply. Your power supply is shot and you will need another to properly run your machine.
Comments:
Sep 25, 2009
- I stand corrected....I also noted that if the AC jack is the culprit it is connected to the main board by a cable making the replacement possible without soldering the connection. I am including two links for the disassembly of the 300 which is a close cousin to the 400. The links are below.
http://tim.id.au/laptops/nec/versa%20m340%20e2000.pdf
This is a video....
http://www.youtube.com/watch?v=uWr1WAVbySc
Was this helpful?
Yes
No
Popular Solutions for NEC Versa VX PC Notebook
Questions and Unsolved Problems for NEC Versa VX PC Notebook
Do you recommend NEC Versa VX PC Notebook?
Answer
Answer
my laptop nec versa stopped to work suddenly bacause of an alteration of the electricity (ups and... (More)
Answer
display is shows but when i'll open to 90 percent display i don't shows how can i repair it
Answer
where can i get a screen for a nec versa L2200 in brisbane and can i install the screen myself
Answer
My NEC Versa M440 laptop could not switch on. There is sign of power present but just couldn't... (More)
Answer
i hv nec nb, my webcam, bluetooth, infrared n wireless doesn't work. please tell me how?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
