Question about Zyxel 24-Port Ethernet Switch
What is the ideal distance from the modem and the switch
    Problem Solver:
  • 17 Answers
The connection between modem and switch is Ethernet, so the official maximum distance is 100 meters. It's unlikely that using any shorter distances will make any difference, so the ideal is anything up to 100 meters.
Posted on Sep 27, 2009
What is the ideal refrigerator temp setting on a smeg sr650xa
It is the same for any fridge. I am a trade chef and catering manager :>)
The ideal refrigerator temperature is 35° F (1.6° C). You're not hugging the danger zone like you would be at 40° F (4.4° C), and you're distancing yourself sufficiently from 32° F (0° C) that you don't freeze half the stuff in your refrigerator.Jun 21, 2013
What Temperature Should You Keep Your Refrigerator Set At?
https://lifehacker.com/what-temperature-should-you-keep-your-refrigerator-set-533534...
what is the ideal refrigerator temp Google Search
Sep 26, 2017 | Smeg Refrigerators
Tip
Tips to Choose a Fiber Optic Modem
Fiber optic modem is good for you, especially when it comes to large amounts of data. With this modem, you can transfer your data quickly and efficiently. In general, this modem is available in two models, the single and multimode. Before buying, be a wise decision to consider certain factors that may be the best for their needs.
When you purchase a modem mode only for businesses, a single-mode modem is ideal for you. It allows some networking systems to share and provide information in large quantities over long distances. This mode also in the light traveling back and forth that allows you to transmit data in both directions simultaneously.
On the other hand, if you need to buy a fiber optic modem for your personal needs, is ideal for multi-buy option. Even if it is available at cheaper prices, it still exceeds the traditional cable connection. With this modem, you will be able to receive and transmit information quickly and easily
Another consideration that you have to do is how you use your computer now and in the future. If you use your computer primarily to receive calls and faxes, a telephone modem to two son to be a good choice for you. It is able to easily translate the phone lines light easily sent by optical fiber.
There are many companies that offer this type of modem you have to do a search. Can help you choose the most reliable product with reasonable price. Check the specs and product offerings to see whether or not it meets their needs. Choose the best solution for your needs.
on Jan 18, 2011 | Computers & Internet
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at...
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Sep 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I can I connect this with a DSL modem/router (2Wire). Ideally I'd like the linksys to do the routing
This can not happen. It is a switch, and not a managed switch at that,
Just let the 2Wire do the routing.
Sep 01, 2010 | Linksys SR224 24Port Ethernet Switch
I face a problem to connect a to office with a 95mtr cat5e cable.switch is not blink on both hands.
95 meters is simply too long. No way of getting a signal on the other end without the use of a repeater. The maximum distance for CAT5e and CAT6 is 295ft, which is roughly 90 meters, but even that only works in an ideal environment. Often the max distance is announced with "300ft = 100m", but that is not true (and 300ft are only 95 meters anyways.)
The best option is fiber optic cable, but that is very expensive.
Read also this article - it has some good explanations and comments.
I would buy a cheap router (WRT54G i.e.) and modify it with some third-party firmware as repeater. That would cost you not more than 25-50$. (Tip: google "Router as Repeater", and you will find many results.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jun 01, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Pressure switch to micro switch distance
The distance is not stable. You have made everything corectly and you how they work.
Now you need to uadjust the distance when the machine is workinig on. The required presure should be 1.2 to 1.3 bar which is the ideal between the temeperature of the milk and temperature of coffee. So you should hear and see the switch going of when the machine reach the above mention pressure.
May 15, 2009 | Elektra micro casa a leva S1 Espresso...
I have dsl connection my server is 6 km fromhome can this affect
distance can be a major player in regards to your signal, may i suggest that you contact your broadband provider
Jan 25, 2009 | Computers & Internet
Laptop only getpoor dsl wireless signal even if standing at base
wireless signal is not from ATT but from the router or modem.
the distance between is line of sign. approximate max distance is 500 ft. you should have not problem connecting it.
The only obstacle is walls, trees, or any other thing between you and the modem.
Nov 14, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Connection problem
how far is the wireless modem to your pc????
could be the distance or the walls in between the modem and the pc.
try to use the pc closer to the modem, if it works, then move back a little, till you cna't connect again. that is the max distance.
do you ahve sercurity set up onthe modem??
if so, you need to connect with exact encyption pass code.
Jul 19, 2008 | Internet KM-2501P Enhanced PS/2 Multimedia...
No longer dialing Lond Distance
If your modem can fax a local number or dial-up an Internet Service Provider in your Local Area then your Internal Modem is just fine. Check if the configuration of your Modem to access outside long-distance number. Go to your Control Panel-Open Phone & Modem Options-Dialing Rules (Tab)- then click on EDIT Button. You can enter the number needed to have a long distance dialing. If you don't know the number needed for long-distance dialing then ask your Local Phone Service Provider.
Apr 04, 2007 | Smartlink (I56KSPF00) Modem
Zyxel 24-Port Ethernet Switch Logo
85 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
