Question about D-Link AirPlus DI-524 Wireless Router
Can't Connect to Internet Using DI-524
I was able to access 192.169.0.1 before I set up my WAN. Now I can't access my router at all. It asks me for a firmware update when it is already updated.
  • oddworldto Sep 27, 2009
    I need this fixed by Thursday before I miss my chance to get a refund!
    And my modem is 1.1 not 0.1. I got 0.1 wokring for teh router for a bit, now its asking for a firmware update.
    Guru:
  • 597 Answers
Most routers the default address is 192.168.0.1 unless you havve a modem that takes that address.
Posted on Sep 25, 2009
We have cable internet provided by Virgin. I am accessing the internet by plugging the ethernet cable dirctly into my laptop rather than via my DI524. Have just read a post that says I have to be connected...
If you can connect to the internet using the Ethernet cable on your laptop then the cable modem is configured correctly.
If you want to connect to the Internet using the D-Link wireless router then first you need to configure the D-Link wireless settings and then configure the wireless card in your laptop with the D-Link's wireless settings. Remove the Ethernet from the laptop and connect it to the WAN/Internet port on the D-Link wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 13, 2011 | D-Link AirPlus DI-524 Wireless Router
Unable to set , even type the password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 14, 2010 | D-Link AirPlus DI-524 Wireless Router
I can no longer conect to the internet through my DI-524 router It was working fine this morning, after I opened a Google document my internet connection was lost. I can connect to the internet if I by...
Assuming that the LED's on the router are lit, try to connect to the router's web interface by entering http://192.168.0.1 in your browser's URL interface. If you can't access it, check to see that your computer's IP address is in the same network as your router. Your PC's IP address should be in the range from 192.168.0.2 to 192.168.0.254. If username and password are required, type "admin" for the user and leave the password field blank (or enter password set by you, if you have changed the default setting). You can check/set your internet connection data under the WAN menu. If you can't access your router by the way above, reset it to factory default settings. To do that, press the reset button on the back of the router using a paper clip, for example, and hold it for 10 seconds. After the router reboots you should be able to access it. Here you can find the manual for your device, for more details.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 29, 2010 | D-Link AirPlus DI-524 Wireless Router
No wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
Sep 05, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Aug 17, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
283 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
