Question about Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Lc37hv4u stuck in standby?
I turned off my tv last night and woke up this morning to turn it on and nothing happened. i pushed power on the remote, on the tv, avc system and the red indicator stays lit on the avc and the display one blinks red.
  • 38 Answers
SOURCE: sharp aquos lc37hv4u tv stays in standby mode,
One of ur fuses has gone bad and u must call Sharp Co.
Posted on Jan 22, 2010
Testimonial: "Thanks for the advice. I have called sharp in the past and gotten no help but maybe with a diagnoses the results will be better."
0 characters
1 Points
My Hitecker 32 inch TV suddenly will not show any inputs other than TV. Worked fine last night. Doesn't this morning. No power surges that are known about overnight.
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 01, 2014 | Flat Panel Televisions
No power
replace the power supply board inside tv
Jan 30, 2013 | Emerson Flat Panel Televisions
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
The TV will not get out of standby
The exact same thing has just happened to me. Im looking for a solution, wont even be ableto get any one out to look at it. Did you end up fixing it?
Oct 02, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Flat Panel Televisions
Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Jul 13, 2009 | Daewoo DLP3212 32 in. LCD Television
Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Jul 08, 2008 | Flat Panel Televisions
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help.
Dec 26, 2007 | Protron PLTV-32 Television
Sharp Aquos LC-37HV4U 37 in.  LCD HDTV Logo
63 people viewed this question
Top Sharp Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a Sharp Flat Panel Television Expert? Answer questions, earn points and help others
