Question about Acer Aspire m5640 PC Desktop
Installing new SATA HD, cannot enter setup or boot
Installing new SATA HD (Seagate Barracuda 1TB) after catastrophic crash, have recovery discs, initially extracted windows files but when recovery disc inserted as directed "Operating System missing" displayed. Changed boot priority to CD, disabled quickboot w/same result. Tried to use Seagate format disc with no results. Now I can't even enter setup or boot screens as it hangs on the Acer splash screen. Has motherboard gone bad as well?
  • 5 more comments
  • Kevin Seitz Sep 25, 2009
    disconnected harddrive from motherboard, rebooted, still hanging on Acer splash screen. still cannot access startup or boot menu
    Did as Vanay suggested resulting in no change. cannot enter setup or even get to BIOS, keeps hanging in Acer splash screen.
    Does it matter that the OS are different? The pc I'm on right now is XP, the one I'm replacing the HD is Vista.
    The pc with the problem is an Acer M5640 w/ Vista OS. The recovery discs are supposedly for this system (ordered from Acer). The pc I'm using for this communication is XP based. From what you're saying I can't format the new drive on this pc because it's a different Windows OS, so I'm back to the same issue. How do I get the Acer pc to boot past the Acer splash screen?
  • Kevin Seitz Sep 26, 2009
    wqell, no success after dc'ing all peripherals: HDD, CD, modem, memory sticks 1 at a time. Still hangs on the Acer splash screen and won't go to Setup or Boot Menu. I was able to get there briefly yesterday if I let the system sit for an hour or so, but recovery still unsuccessful. I guess I'm off for another pc, DEFINITELY won't be Acer ever again. This system is only 16 months old. Unless you have an ace up your sleeve, I guess this POC is history. Thanks for some decisive troubleshooting.
    CMOS reset resolved the hang up on the splash screen. Now attempting to install new HDD and recover using Acer supplied recovery discs...again.
    Well...Windows files were extracted from the system disc, 1st recovery disc inserted and the system rebooted. Now I have black screen with "Missing Operating System" which is where I was when I started the new HDD install a week ago. Any ideas? So far you've got a good track record.
    No, now when I put the 1st recovery CD in I'm gettin "Recovery32 Type mismatch" When I click OK a screen comes up that says to wait and nothing ever changes. I've been doing a lot of reading and I'm not the only one ever to have this problem. It seems that I should have formatted this disc to put the partitions in place before attempting to use the Recovery Discs. But now that I have attempted to recover to this HDD, how do I wipe it clean and start over? If that is the issue. I have tried downloading .iso images and burning them to a CD and booting to those but all I get is Operating System is missing.
  • 2,229 Answers
Remove all the devices connected to the motherboard. Try to boot with only CPU, Video, and memory. If the works, try the hard drive.
If you still have a problem, it could be memory. If you have 2 sticks installed, remove one of them.
If still no boot, then you, indeed, have a motherboard problem. It's failing the POST.
Posted on Sep 25, 2009
  • 2 more comments
  • Art Ellison
    Art Ellison Sep 26, 2009
    Only other thing I would do is clear the CMOS
    Disconnect the CMOS battery.
    I think Acer has a jumper near the battery to clear it. Move the jumper to the clear setting and then back. Reinsert battery.
    Now try it.
  • Art Ellison
    When you put in the first recovery disk, it booted from the CD, correct?
    Now when you put in the second one, did it ask you to press any key to boot from the disk? If it did, you should just ignore it. It should only boot from the CD once. Othewise, you will get that message.
    Keep trying!!!!!!!!!!!!
  • Art Ellison
    Sorry it takes me a while to get back to you. It's Saturday and I'm out doing stuff.
    Going next door to a Bar-b-cue next!
  • Art Ellison
    Art Ellison Sep 27, 2009
    I'm not really familiar with the recovery disk for this computer, but when you put it in, does it just start the recovery?
    Do you get the option of doing anything else?
    When I format a hard drive, I do it with a Windows system disk, which is about the only way to do it.
    If the recovery disk gives you an option to go to the command prompt, you can then use the format c: command.
    I assume (perhaps in error) that you have checked the configuration of the hard drive in the setup (COMS setup) before you actually try to do anything.
    When configuring SATA drives, some computers get a little fussy how you set them up--if the motherboard allows a RAID setup, sometimes you inadvertently configure it incorrectly.
    President:
  • 2,600 Answers
My first question to you would be, do you have access to another computer, laptop or desktop it doesn't matter. I usually "initialize" new drives on another computer by using an EIDE / SATA to usb adapter. That way the new drive will read as just another hard drive once it is initialized and easier to work with. If you would like to try that, an adapter is about 20 dollars at a computer retailer. You would hook the hard drive to the adapter and plug the usb cable into the computer. Then go to control panel > administrator tools > computer management > look to the left lower cloumn and click on disc management. Your new hard drive will show up there as either an active hard drive with a drive letter or a an un-named drive with a blank box next to it. If there is a drive letter etc. delete the partition and start over making another. If there is no drive letter, right click on the small tan box that lists the drive and "initiate" the drive. When done, try to boot up again in your original system and run your restore discs. Get back to me again if further assistance is needed.
  • Chip
    Chip Sep 25, 2009
    Just install the windows operating system into the computer. The problem you are having is the computer and its restoration discs are based on the Windows XP operating system. You can load the Vista operating system but the restore discs for the applications are not going to work on a Vista installation. Once the Vista operating system is installed and fully updated....don't install anything until the operating system has gone through all of its updates which may take an hour or two after numerous reboots. After the updates have stopped, you can try to put a restoration disc in and instead of letting it auto load, hit cancel and go to my computer > right click on the cd drive and click on explore. A list of the folders on the disc will appear. In some cases the individual programs may be listed in their folders and each may have an installation file in them that would allow you to install them manually. If these are XP and XP only programs then they may not even install. What I would suggest you do is go to the manufacturers website of the computer, go to the support/drivers page and see if they have any updates to the programs that Vista will support. There may be some but then again, there may not be any and you may have to go online to find free programs etc., which there are plenty of. Go to www.filehippo.com and www.download.com, these two sites have hundreds of free open source programs that equal any paid programs out there and are fully supported by Vista. I hope this helps you out with your problem. You should have no problem just installing Vista and running the Updates....do that first and worry about the programs after. Good luck.
  • Chip
    Chip Sep 25, 2009
    Please, when you do the updates on Vista, just do like 10-15 at a time....try not to overload the update downloader with 40 updates....Vista has a habit of choking on too many at one time. Just want you to have a smooth transition.
    President:
  • 1,884 Answers
No. The motherboard is fine. remove the HDD from the mother board. Now enter BIOS and check the HDD on the first page. It should not be there. Re attach the HDD and enter BIOS again and check for the HDD. Should be there. If not , then auto detect the HDD. Then proceed with Windows Installation.
Recovery discs won't install windows on new hard drive
sad to say but probably have to buy a new operating system disk .
May 13, 2015 | HP Computers & Internet
Require replacement power/data pcb for a seagate barracuda 7200.11 1000Gbytes part number on PCB is 2HBAHNRQ
Contact your local computer store, a computer technician/data recovery technician may have just that circuit for you to use and transfer your data onto a new hard drive.
You may also try to contact Seagate in this regard, they offer 3 year warranty on all Barracuda hard drives.
Take care!
damnor01
May 28, 2011 | Seagate Barracuda 7200.11 - hard drive -...
I HAVE MY MASTER 160Gb SATA SEAGATE, I HAVE TO ATTACH A NEW 500Gb SATA SEAGATE ,I'VE GONE TO BIOS SET UP. BUT IT DOESN'T DETECT MY NEW DRIVE.CAN YOU SHOW ME THE WAY TO SLAVE A SATA SEAGATE HARD...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
May 16, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My Seagate 1TB SATA hard disk's PCB main I.C. is Broken & noise of Clicking and Not Detecting in BIOS.. I'm in big trouble please help me.!!!!!PLEASE PLEASE....
I am afraid the device is dead. You may be able to recover the data from a professional recovery firm but there is no other way.
Dec 20, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My seagate barracuda 80 gb sata was unable to format completely how to solve this problem? pls helm me
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
this process should enable a complete format
hope this helps good luck
Sep 18, 2010 | Seagate Barracuda 7200.10 ST380815AS 80 GB...
How to extact the data off the Seagate Barracuda 7200.10 320GB HD
if its your motherboard that crashed then ther is no problem with your hard disk. connect your hard disk to any other computer and you can access all the files in it.
if it is your harddsik that crashed then try recovery utilities like western digital data storege manger or any other disk recovery tool available for free. if still it fails then you can recover your data if you hand over your hard disk to the nearest service centre. but recover from a hard disk only if its very valuable. thay will charge you per MB of data recovered
Jul 04, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Need Help
Usually the beeping sound when powering up the drive is an indication that the drive is damaged.
Nov 22, 2007 | Seagate Barracuda 7200.9 300 GB SATA Hard...
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Acer Aspire m5640  PC Desktop Logo
360 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
