Question about Logitech Harmony 890 LCD Remote Control
Hi my harmony 890 pro works for a short time then as soon as I press a command it will send a command , the device will turn on and the remote then completely shuts down and nothing will happen at all... if I take the battery out wait an hour or more put it back in it will then work fine for a few hours then does the same thing again,, Any help would be appreciated . Thanks, Brian
    Scholar:
  • 89 Answers
Hey!
You might need to do a firmware update!
I have found when my remote is not working right at all it always helps! Hope this link helps you like it did for mine!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
-Kennedy
Posted on Apr 02, 2010
I have a harmony 890. it turns all the equipment on/off properly except the TV (a Vizio). this works intermittently. suggestions?
Hi. Try learning the power commands for your Vizio TV from the original remote. The power commands that the Harmony remote is using may not be correct. The following tutorial by Logitech will assist you with this.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9605
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
Tip
Harmony 890 Pro Manual Download
Download Logitech Harmony 890 Pro Remote Control Manual
Have you misplaced your Logitech Harmony 890 Pro Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 890 Pro Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Televison & Video
Harmony 890 Remote - kids watched a movie last night and now the screen is zoomed and we don't know how to get back to regular view. They swear they only used that remote.
On the remote, press "Devices" and then select the TV. There should be a command on the LCD screen that is called somethine like Zoom, TVZoom, or a ratio such as 5:10 (the numbers could be anything). If not, test all of the commands. One of them will fix it.
Jul 25, 2010 | Logitech Harmony 890 LCD Remote Control
My Harmony 890 remote has a difficult time inputing numbers
Hi. This problem is caused because the 'repeat' setting on the device that you use to change channels (TV or cable box) is too high.
1. In the software, click 'Troubleshoot' next to the icon for the device that you change channels on.
2. Select '<device> responds to some commands either too many times or only occasionally' and click NEXT.
3. Decrease the setting by one (the default is usually 3).
4. Update your remote and test it.
Apr 25, 2010 | Logitech Harmony 890 LCD Remote Control
My Harmony 890 turns everything on and off, but when I am in PVR it just suddenly stopped letting me use any of the buttons (ie, menu, guide, channel, volumn). what do I do
I would hook the harmony back up to your computer and the update the remote. If that does not fix the problem then I would down load the firmware and then update your remote. If you still have problems I would check your check your buttons in the program. You can do this by logging onto your Harmony account, select the Activities tab and press on the “customize buttons” under the activity you are trying to fix. Scroll down to the menu exit info buttons and see if there assigned to the correct device and correct command. If none of this works I would see if the menu button works in another activity like Watch TV or Watch DVD.. If the menu button does not work in another activity then the remote may be broke. If it does work then I would try the original remote with your DVR and see if that works. If that works then I would manually teach the harmony remote. Harmony calls this “Learn command” It’s a button in the lower right corner while in the “customize button” tab.. If none of this works then pull out your 45 and put a hole in it.
Hope this helps
Nov 28, 2009 | Logitech Harmony 890 LCD Remote Control
I have a logitech 890. The remote only turns the tv on and off but nothing else.
this remote has a help button to resolve setup issues. you should see a message on the screen ask ing if you need help. If not this function can be activated using the setup software. Try using the remote to watch TV. Then press the help button(be sure to have the remote pointed at the TV). The remote will attempt to fix itself. the screen will then ask if that fixed the problem-choose yes or no. Continue to follow the prompts until everything is the way you want it.
This should get everything working for you. I assume you did connect the remote to your computer and went through the setup software.
I use this remote and I love it. Just be sure when using it to give time for it to send commands to all the devices.
Nov 06, 2009 | Logitech Harmony 890 LCD Remote Control
The power flickered on and off last night and since then I cannot get my Harmony 890 remote to change channels. We have Direct TV. It will control the volumn and turn the tv on and off, but will not...
You DirecTV device may have been reset ack to RF. You'll have to make sure the device is set to accept IR commands in order for the Harmony remote to work on it.
This link will help you.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12985
-D
Oct 31, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony 890 Pro will not pair with Xbox360
The RF signal is on the XBOX is used for the controllers only.
When using the Harmony 890 with a 360, you will have to use it as an IR (infrared) device. That is the only way to use a remote with the 360. If you have an extra port on your RF extender, you can place the end on the remote senor on the 360 (located under the eject button).
I set these remotes up weekly, it is a product I recommend to people all the time!
But again, the only way to setup a remote with the 360, is to use the IR port as a standard IR remote. Since the controllers run off RF, the learn function will not work, unless you already have 360 remote control to use to do the learn function.
Hope that offers some insight. This information can also be verifies at Microsoft XBOX 360's FAQ page.
Oct 21, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony 890 Remote
in the harmony remote software (7.4.3) go to the device (Bell receiver) under the devices tab and select settings. select the second radio button (adjust power settings) and click next. select "i want to turn this device off when its not in use" and then click next. Continue answering the questions, and then update your harmony remote.
Apr 22, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
42 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
