We have a One for all TV control. It stoped working
We have a One for all TV control. It stoped working and I but in new battries tryed to put in the code number that I had written down when we got the control still did not work. I took it back to the store where I got it. They would not give me a new one (which is want I wanted) they would not give me the money back. What can I do since this has a life time warrant on it. Thank you Connie
  • 403 Answers
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
Remote not working as i moved tv into another room
If the remote control you've bought is a universal remote control, you have to set it with your TV, by TVs setup codes. The setup code list will be attached to the new remote controls' packing. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy
Nov 06, 2013 | Grundig GU22DVDPX 22 in. LCD TV
Phone full battery but wont turn back on
may be battry is outdated or extra fully charged thats why sometimes it react like this or the size also bigger than normal battry so try new battry or check the PIN which is connected to battry when u put battry in mobile...thank you
Nov 03, 2013 | Samsung Galaxy Pocket
My remote will not work and the parental controls are locked on the set, so the TV will not do anything.
  1. try to clean it or change the battry or quartz 455 mhz
  2. buy a new universell rc and put the code of your tv
  3. good luck
Dec 06, 2010 | RCA 32V550T 32" TV
Buttons won't work it seems it doesn't send the signal to the receiver.I got new battries but still won;t work
Try to check the remote Model matches the Receiver's model number. If it does not, then try to get Universal Remote Controller
Jan 30, 2010 | Denon RC-H800 Remote Control
Camera will not turn on...charged battery but the charge light blinks instead of staying solid
If battries still blinking , chances are that the battries are buggred...try new battries after fully charging...this is cheaper option to try before trying to open the camera..
May 20, 2009 | Casio Exilim EX-Z77 Digital Camera
Magnasonic MCT5555 TV remote control will cycle through 02 - 32 but when trying to go above 32 it returns to 02. I can manually select any number above 32 say 43, 55 etc. but will not cycle up on remote....
Steve from Magnasonic 800 663 5854 solved the problem. It must have been finger problems - somehow someone programmed the remote unintentionally. Steve had me turn on the TV and press 02 | RESET | AUTO -- the tv cycled through all the channels -- and that cured the problem.
Jan 14, 2009 | Televison & Video
Blackberry 8800 buttons
Try pulling the battery out again, but this time when the device is on.
Mar 27, 2008 | RIM BlackBerry 8800
Ilo hd tv
Hey try unplugging your television and taking the batteries out of the remote control.. Wait about 5 minutes and try it then! Did that help? If not, your remote control code be broken or it could be your television, but most likely the remote, so I would recommend purchasing a new replacement remote control from a site like http://www.remotecontrolscenter.com instead of buying a universal remote control that you'll have to spend hours trying to program to work with your tv, instead the replacement remote will be an exact replacement for that broken remote control. Hope that helps!
Sep 06, 2007 | iLO V27DMBX Television
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
