Question about Garden
I have an MTD ridind mower I need to replace the blades what size wrench fits the nuts on the spindles ita a model #13BN771G729 Thanks
  • 62 Answers
5/8 I DO BELIEVE
Posted on Sep 25, 2009
When taking off the blade for replacement one side of the attachment assembly broke off. i can't figure which nuts/bolts to loosen to remove that part for replacement
The spindle assembly is usually held in place by bolts through the mower deck. The deck will need to be removed from the mower to get to them. There will be three or four of them at the base of the spindle assembly, remove these and the spindle will fall out the bottom
May 15, 2016 | Mtd Garden
How to remove a stuck bolt on blades on riding mower.
The blade bolt can be very difficult to remove sometimes and will require an impact wrench. If that doesn't work, you will need to heat up the nut only with a Ox/Acetylene torch, then it will remove easily. Do not heat the nut too much or it will ruin the thread on the spindle when it comes off. Remember to heat the nut only.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replacing a MTD spindle assembly
Yes, most spindles come with non threaded holes. The metal is soft and you can just use regular bolts. Once you start them, they cut their own threads.
Jun 02, 2012 | Mtd Garden
I have a Ryobi WS730 wet saw. I suppose the manual was discarded by my wife with the box. I need to change the blade and do not find a stopping mechanism to hold the blade while I use a wrench on the...
The saw should have come with a wheel wrench and a hex key. The hex key will act as your stopping mechanism if you hold it.
With the saw unplugged, loosen the wheel guard lock and rotate the wheel guard to expose the arbor nut. Put the wrench on the arbor nut and a hex key in the spindle. Keep the wheel from turning with the hex key and loosen the arbor nut with the wrench (turn counter-clockwise). Then remove the hex key, wheel wrench, arbor nut, and outer washer to access the blade. Remove the old blade then wipe a drop of oil on the inner washer. Place the new blade on the spindle. Replace the outer washer and then the arbor nut. Again use the wheel wrench and the hex key to tighten the arbor nut while keeping the wheel from turning. Then replace the wheel guard and tighten the wheel guard lock.
The manual is available from Ryobi: http://www.ryobitools.com/catalog/power_tools/tile_saws/WS730 . The direct link to the manual is http://www.ryobitools.com/product_manual/file_url/11/WS730_414_eng.pdf .
I hope this helps.
(If you can't find the hex key, get another that will just fit the opening in the spindle.)
Jul 05, 2011 | Garden
Have difficulty removing mower blades. find it impossible to remove the nut. is it left or right hand thread ?
The threads are right hand....
wedge a block of wood into the blade to hold it
then you can really push on the nut...
also make sure you have a good fitting socket wrench
add a pipe on the handle for more leverage...
you also can heat the nut to red hot and then let it cool
which will also help to loosen it...
heatman101
Apr 02, 2011 | Mtd Garden
Black & decker mm850 can not get blade off so can replace how do I get off tried loosen clockwise and counterclockwise plates move will not loosen up
The nut is counterclockwise but will most likely take an impact wrench to remove the blade because the impact will not need the blade or spindle to be held in order to remove the nut.
Thanks,
Chad
Mar 23, 2011 | Garden
Mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Aug 23, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
My Swisher Rough Cut 12.5 HP 44 Inch mower - The blades stop cutting when I hit a dense patch of grass. The belt and the pully are still moving at normal speed but the blade slows. Also I can spin the...
I dont believe there is a shear pin on your blade spindles, what I have found on these machines is the the spindle nuts on the balde spindles sometimes loosen or wear and no longer squeeze the pulley on the blade spindle. To make this process easy on your self you need to tighten these with a impact wrench. However if you dont have access to a impact wrench you can use hand tools and block the blades you are trying to tighten with a wooden block. Just make sure you block the blade you are trying to tighten
Aug 13, 2009 | Swisher 44-Inch 12.5 HP Trailcutter...
How do I remove the spindle from the deck of a Craftsman mower.
Put your blade back on so you will have some backup on the nut. Wedge a piece of 2x4 between the blade and deck to hold the shaft while you take off the nut. You should do that before unbolting the spindle. If you are just replacing bearings, you don't have to unbolt the spindle at all. Just remove the pulley on top and the shaft with blade attached will slide out the bottom. The botton bearing, however, will be on the shaft and is difficult to get off. I use a bearing splitter to get it down far enough to drive off the shaft.
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
