Question about Maytag Dryers
Maytag dg713 dryer is no longer lighting? Wondering if it involves what tells the coil to light or if the coil itself needs to be replace?
  • Maytag Master
  • 8,220 Answers
The timer runs a hot leg over to the control themostat and then through a centrifugal switch on the motor over to a fuse on the blower housing and into the gas assembly itself. When power is applied the ignitor gets real hot 1800F. The sensor is also in the same circuit as the ignitor and the gas operator coils. The coils won't yank open the gas till that ignitor goes out because it is hogging most all the juice. The sensor kicks out and kills the ignitor, both drop out of th circuit. That unleases the amps to them coils which yank up the gates and let the gas go flowing out to that hotazz ignitor. Kawooosh!!! Houston we has ignition.
Posted on Sep 25, 2009
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
Maytag Neptune MDG5500AWW Not Heating
The coils are the #1 failure in gas dryers, below is a description of how they work. This excerpt from; www.repairclinic.com.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Jul 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Gas dryer work but doesn't get hot
Tell your natural gas company that you smell gas around your gas dryer and you think there may be a leak. They will send somebody out, at no cost to you to check on the appliance (gas dryer). When that person gets there, they will re-light your appliance and if the gas dryer needs a new thermal coupler, they will show you where it's at and how to replace it.
Jan 05, 2009 | Maytag Performa PAV2200
Not heating for my MayTag commercial Dryer
You need to remove the front panel and check to see if the glow bar is lighting. If it is and you aren't getting any flame 1 of 2 things can be wrong the gas coils could be bad or the gas valve itself could be bad. the easiest way to check the gas coils is to take off the front panel (you will need either a philips head screw driver or a T20 security star bit) and loosen up the bracket that holds the gas coils down. Don't remove the screws completely. start the dryer and lift up the bracket. If it seems like the coils are pulling the bracket down then the coils are good and you will need to replace the gas valve
Dec 25, 2008 | Maytag MDG16PR Gas Commercial Dryer
I'm moving and am taking my Maytag Atlantis W & D with me. The moving company said I need to disconnect the gas lines or they won't move it. How do I do that? Is the metal coil that appears to be the...
the dryer does not have any gas lines those are all part of your installation, there should be a shut off valve for the gas supply behind the dryer itself,YOU NEED TO TURN OFF the gas supply to the unit before disconnecting. the moving company wont do it for the liablity of blowing up your house! if you dont feel comfortable disconnecting a gas line or are uncertain of gas being off to the unit I STRONGLY reccomend that you have a qualified person disconnect your appliance.
Oct 25, 2008 | Maytag Dryers
Maytag Ice20 refrigerator
You have a bad high voltage board and as the other user said call the manufacturer they are assisting with this problem.
Jul 09, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
After first Ignition cycle igniter stays on too briefly to open gas valve gas.
Valid Most likely the problem with your dryer is the coils for the gas valve. Remove the access door (on the bottom right side on the front panel) and you can see the gas valve with three coils on top of it. They are coming as a kit with complete instruction. The part number for this kit is AP2669614.You can buy it here http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542517043&type=10&subid=
Jan 16, 2007 | Maytag MDE2706 Electric Dryer
Dryers Logo
110 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
