Question about LG 42LC2D 42 in. LCD HDTV
Screen displays no signal after a power failure; can hear sound, no picture
    President:
  • 632 Answers
It's either the backlight lamp or backlight light inverter is busted due to the power failure.Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Posted on Sep 25, 2009
I can hear sound on my sony tv21 but no picture display
check the EHT status, wether it is ok then check the filament and related components.
Feb 02, 2013 | Televison & Video
I have a philips 9p6044, and there is no picture or audio. It has power, but there is no display or sound. What can be the problem?
On that model if its making a constant chirp sound while powered on? If so then its most likely a convergence failure.
If its not chirping then the next most common failure is a power amp. Both are realtively easy DIY fixes. The website www.tvrepairkits.com has complete kits for both. Hope this helps.
Jan 28, 2013 | Philips Televison & Video
Chrysler town and country; rear seat dvd has no picture. Hear sound. Get picture and sound from Auxillary jacks so it is not the screen. Ran cleaner in player. didn't help
If you are getting sound and picture from the screen's auxiliary jacks, then this only confirms that the screen is faulty. The DVD player must be reading the picture signal as it supplying the auxiliary jacks, but the screen has failed to display the signal.
Nov 06, 2012 | 2002 Chrysler Town & Country
When i turn my ps3 on i get no menu screen. tv says no signal and have a blank screen. as soon as i put a game in i get the picture on the tv
It sounds like your PS3 is putting out a resolution that your tv can't display when it is on the menu screen. The fix for this would be to press and hold the PS3 power button until you hear two beeps. This will default it to factory display settings and should set it to a resolution your TV can handle.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
Monitor comes on but wont show picture
You should make sure the cable is plugged into the video port on the back of the tower. Also, if you have more than one video card, ie an "onboard card" and another card that was added later, try alternating one to the other and see if the other one works. You can identify video ports by finding the blue pentagonal plug. It also will be the only plug that your monitor cable fits into (that is describing a VGA cable, a white cable is a DVI cable and is even easier to identify.) You might also want to make sure the video card wasnt jostled out of place. The final solution could be you have developed some bad memory modules, or the memory was jostled out of its slot during the move.
Jan 03, 2009 | Dell Computers & Internet
Samsung LNS2641D 26-Inch LCD HDTV lost its picture
I'm afraid that while their intention was good, that most the posted solutions miss the mark. Let me guide you thru the diagnosis and possible cure. This is detailed and lengthy, since these points appear often in LCD TV/Monitor repair. You may wish to warm up your soldering iron and skip to Step (11) for the repair procedure.
(1) We know that much of the Main Power Supply is working since many of the audio, video and digital processing sections appear to be working (sound, remote control, tuner, and video out).
(2) We know that the Backlight Inverter is working. Even thought the screen appears to be dark, light from the backlight tubes can clearly be observed. Further, even thought the screen is dark, you *can* observe a small amount of the backlight thru the screen.
(3) When working on LCD TVs and Monitors, the typical problem is backlight failure. (Fortunately this is NOT the case here.) Backlight failure is most often due to Backlight Inverter failure, or Main Power Supply failure. Rarely do the bulbs fail outright (although occasionally thru abuse a CCFL tube is cracked or shattered).
(4) The typical failure mechanism on LCD TV/Monitors that have many in-service hours on them is CCFL tube aging. As the CCFL tubes get older they require increasingly higher voltages to maintain the proper regulated current thru them which in turn creates the correct light output. The higher voltage is often beyond the design limit of the Backlight Inverter leading to component failure. Typically discharge breakdown arcing on the output transformers (that drive the CCFL lamps), or drive transistor failure in the Backlight Inverter power supply. Alternatively, the Main Power Supply may fail. Typically the Main Power Supply supplies +12V, or +15V, or a higher voltage (+24V?) to the Backlight Inverter subsystem. Once again, as the lamps age, more current is drawn, and if the Backlight Inverter doesn't fail outright, it draws excessive current from the Main Power Supply leading to either Main Power Supply failure. Alternatively, the Main Power Supply protects itself by shutting down once the excessive current is detected. This can often be seen as "monitor cycling" where by a LCD Monitor will initially power up, but subsequently cycles every few seconds as the Backlight Inverter draws too much current causing the Main Power Supply to shut down. Then, after a brief recovery period, the cycle repeats.
(5) Another failure mechanism, that should not be overlooked, is Electrolytic Capacitor failure. The Internet has many sites documenting either manufacturing defects in Electrolytic Capacitors used in any of the subsystems (Backlight Inverter, Main Power Supply, Digital Signal Processor, etc.). However, more often than not, Capacitor failure is due to component stress-due to the high ripple currents present in inadequately designed switching power supply subsystems. Additionally, many inferior Electrolytic Capacitors of Chinese origin are inadequately designed-they lack trace chemicals in the Electrolyte necessary to assure long service life.
(6) If you suspect any of the mechanisms described which cause an absence of CCFL backlight, you can often use a small pocket flashlight, and observe the screen image *is* in fact present on the LCD panel, but in the absence of sufficient backlight, you mistakenly believed the LCD panel to be dead.
(7) This is not the case here. We can clearly see that the CCFL backlight *is* lit, but we also do *not* observe any image on the LCD panel, even with an external flashlight.
(8) Thru this diagnosis of exclusion we assume that either the LCD panel itself is defective, or that the LCD panel is not receiving the correct drive signals from the Digital Signal Processor subsystem.
(9) A cursory examination reveals that the Digital Signal Processor board is producing output activity, which-even if malfunctioning-would likely produce some sort of LCD display activity.
(10) The LCD panel is totally dark (backlight is on, but no image at all). This failure is so absolute, it leads one to suspect power related problems as opposed to logic or drive problems.
Nov 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
42" LG RZ42PX11 Plasma - rainbow lines on whole screen but sound
hi there.its likely that the lower y-drive panel has died.this is a very common problem with this model.the easy way is to remove the panel from the set completely,power it up and you should be greeted with the top half of the picture.this means ic failure,usually the bottom one for some odd reason.not replaceable unless you have the gear,these ics are available from dalbani(nikkai)for those interested.be extra careful with the four ribbon cables when removing/refitting.damage to these writes off the display panel.hope this helps somewhat,regards,steve.
Feb 03, 2008 | Televison & Video
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Sep 19, 2007 | Emerson EWF2704 TV
LG 42LC2D 42 in. LCD HDTV Logo
322 people viewed this question
Computer Repairing
Computer Repairing
