Question about InFocus ScreenPlay 7200 Multimedia Projector
Can't start infocus sp7200 after changing lamp.
I had 20 hours to change lamp but it shut off before that time. Changed lamp but cannot start it up. Power led is on and I can hear the fan, but won't start. I did not reset the lamp before it shut off. Help please with my infocus screenplay 72000 problem.
  • thedigitaldo Sep 25, 2009
    I did change the bulb. But when I tried to power it up, the power button is lit up solid green and I can hear the wheel, but no light. I tried to reset the lamp counter but of no avail.
    Thanks.
  • Neo32 May 11, 2010
    I'm assuming that you replaced it with a new bulb? Do you hear the color wheel spinning?
    Scholar:
  • 167 Answers
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Posted on Jan 16, 2010
How do I reset the lamp timer for the infocus LP925 projector? Are there other problems that could cause my issue?
hi
this lamp has a small lamp pcb with a chip on it.
have u change the complete module or have just changed the bulb.
if you have just changed the bulb then u have to replace the small fuse on the chip.
this should help to reset the lamp timer!
Apr 07, 2015 | InFocus SP-LAMP-LP9 Projector Lamp for...
I have an Infocus IN2102EP projector. It was shutting down after several minutes of use. I contacted InFocus support and they advised to change the bulb. I've changed the bulb and reset the bulb hours. ...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 04, 2011 | InFocus In2102 Projector
My SP7200 sometimes projects flashing white
it may not be the projector as a bad ground. try it with a different plug in a different room. if the problem persists, it may be a bad lamp. if the lamp is older, flashing may occur.
Oct 28, 2009 | InFocus ScreenPlay 7200 Multimedia...
Toshiba MT8U projector strikes lamp then goes out
it's the ballast or power supply. the lamp gets about 250vdc until it reaches a certain point, then it drops to about 20vdc, but the high strike runs through a different part of the ballast than the maintenance voltage.
Jul 07, 2009 | Toshiba TLP 680 Multimedia Projector
Bought a replacement lamp for Infocus SP7205. Lamp works fine. But the fan intermittently will come on at high speed for 5 seconds, then turn off, then do it again a minute or two later. Slightly...
I seen this problem with lamps that are not from infocus. I would recommend to replace it with the old lamp fan. if you still have it. I'm not sure why it does this.
Apr 25, 2009 | InFocus Lamp Projector Lamp for LP650,...
I want to test my infocus lamp to know if it is burnt
Your lamp might be ok, but you power supply is dead. If your not seeing any led lights come on when the power cord is plugged in then your power supply is dead. I can fix this for you for less then it cost to send to infocus or to a repair shop. Ebay Id is Gtitubro
AIM - Gtitubro
Feb 12, 2009 | InFocus Lamp Projector Lamp for LP650,...
My in1 projecter keeps turning itself off
if the lamp has 2000 hors on it, it needs replacing. go into the menu and find out how many lamp hours are used. it could be the lamp and it could be the ballast.
Nov 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 7200 Multimedia Projector Logo
552 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
