Question about Sony PlayStation 2 (PS2) Console
Dun screwed up need info please
Pulled off the ribbon from the top lid to the consle how do you reattach
    Uploaded 5 video answers.
  • 152 Answers
Posted on Dec 18, 2007
How do I change the lcd/vga cable on asus v550ca laptop
A flickering screen indicates a backlit problem. I would personally change out the screen but if you want to do a complete diagnostics and take the long way in which you'll learn a lot.
Tools needed:
Dollar store jewelers screw driver set.
Soft cloth towel
To replace the screen only:
On the screen there's little screw covers on the corners of the screen, removing these sticky little covers will give you access to the screws that hold the screen cover on. Once removed get a guitar pick or even a finger nail and go gently around the screen. Once the screen cover is off you will see the screws that hold the lcd in place and screws that secure the hinges.
Locate and remove the screws that secure the lcd to aluminum side rails. Use the soft cloth towel to protect the screen from getting scratched during removal. Lower the screen towards the keyboard and lay it down on the keyboard.
On the back of the screen you will see a ribbon cable attached to the back of the lcd screen. GENTLY pull down the ribbon cable lock on both sides of the ribbon cable.
The only thing left connected to the screen is the backlight cable, GENTLY pull this plug out taking note of what color wire is on the top and bottom.
Reverse this instruction and happy computing
For COMPLETE laptop dis-assembly follow this link:
Follow this link for complete disassembly instructions with pictures for your laptop. You may want to skip to when the screen gets disassembled.
Nov 21, 2014 | ASUS Computers & Internet
The glass of scanner hp2510 is broken how can i remove it and fix it
I can tell you how to get access to the glass panel, although I cannot remember how easy it is to remove the glass itself:
First remove the lifting lid by unplugging the jack plug connector at the back, then riase the lid to vertical position, pull the plastic tab in the middle of the hige towards you and wiggle the lid upwards so that it comes out. Then pull off the keypad label plate, then gently pull off the control panel (which has two ribbon cables attached) by sliding it forwards from back to front of the printer. Disconnect the ribbon cables from the control panel (they pull off) and thread the cables back through their retaining clips on the top cover. Now you can remove all FIVE retaining screws (Torx T-10 driver required) from the top cover and lift it off, leaving the ribbon cables in situ. You can then turn the top cover over and work on removing/ repairing the glass. I would say it s not worth bonding - just get a new piece of glass.
Mar 25, 2013 | HP PSC 2510 All-In-One InkJet Printer
E-2 message on schwin 420
You may be able to reset the main board by detaching the ribbon connector, then reattaching it. Unscrew the four screws that hold the display panel, and you will see a ribbon connector and a round connector. Gently squeeze the tab in the center of the ribbon connector and pull it off. Wait a couple of minutes, then reattach the connector by gently pushing it into the socket. The display should show a boot-up process and then the normal blank screen with the prompt to select user. If the E2 error returns, repeat the process. If this procedure does not reset the board, you will need to contact Schwinn about possibly replacing the board. You can contact them by going to ( and select the "email us" link or call the 800 number.
Jan 30, 2013 | Schwinn 420 Elliptical Trainer
I need to know how to change a emachine e440-1680 laptop keyboard.
Should be able to remove the shroud of the top of the keyboard (the long piece right infront of the monitor) with a screwdriver. Once that is removed there should be 2 screws revealed. Remove these scres and slide the keyboard towards the monitor and pull up. There should be a data ribbon connected, disconnect that and you have the keyboard out. Attach the new data ribbon from the new keyboard, slide it into place, put the scres in, reattach the shroud and your done! it's actually pretty easy.
Feb 04, 2011 | Computers & Internet
My washer will wash on any cycle but it will not go to the next step to spin the water out
check the lid switch most likely this is your problem.... they put the lid switch on there so when you raise the lid it shuts the motor down and stops is a safety device... if the unit is working on everything else you most likely have a bad lid can bypass to confirm prior to buying a new one.... good luck.... whirlpool models you have to remove 2 screws in console and flip consle over will see a molex plug usually on right side under console with a 3 prong plug... take a jumper and jump out the side coming from the console normally 2 outside terminals. plug unit back in and see if it works....
Jan 03, 2011 | Whirlpool LSR5132PQ Top Load Washer
Dyson CR01 front panel removal help
Remove lid, two screws at rear, slide back and lift. Remove control panel, two screws at top, lift and remove ribbon cable. Outer door, open and remove screws from hinge. Front panel, remove two top screws. Front panel lifts up and inch and pulls foward. You might need to move penny trap. To do this, remove rear panel. Right lower hand side, remove motor and mainboard to facilitate space for and arm, have fun! Penny trap and pump are not screwed down. They are hooked over the front metal plate, just lift and pull backwards! I had to remove everything from the machine just to get at the penny trap!
Oct 23, 2009 | Dyson CRO1 Front Load Washer
I need to replace keyboard from acer 4330. any tips ???? Thanks
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
Jun 04, 2009 | Apevia Laptop Keyboard for Acer Aspire...
How do I remove the display panel from an Acer 3000 series laptop?
Remove the 3 screws at the Base of the Screen, Open the Screen all the way horizontally, and Take off the Trim Piece covering the Buttons. Remove the Cover to the RAM/Wireless Bay, and remove the Two Wires on the Wireless Card. (Be Sure to Close the Laptop before you remove the either the Upper Trim Cover or the RAM/Wireless Bay Cover.) Remove the Keyboard, and pull the Wireless Antenna Cable through the Case and out of the Machine. Remove the Ribbon Cable from the Motherboard, and remove the 4 screws securing the screen to the rest of the Laptop. installation is reverse of Removal.
Jan 17, 2009 | Acer Aspire 3000 Notebook
Hp 8250 printer
Hi, Just took mine apart.
Lift up the lid, and squeeze the clips on the supports, and pull the lid toward you. Lid slides off. Then look along both sides ( edge ) of the printer, you will see about 3 elongated holes. Push a small flat screwdriver through these to release the clips which hold on the grey trim around the edges.
Next slide the rear part of the trim to the left, to remove it. At this point you should undo the 4 hex screws that hold on the top ( the lid is attached to it by ribbon cable ). There are two at the front, two at the back ( the ones at the back are in 'tunnels' ).
Ribbon cable will unclip from the right side of the printer ( the circuit board ) and you can set the lid / top aside. The actual side of the printer simply hinge out. Everything else is fairly straightforward.
May 13, 2008 | HP Photosmart 8250 InkJet Printer
I need to open Playstation2 old
You need a knife to pick the Screw covers out from the back. Also cut the Warranty label at the case seams. Using a #1 phillips screwdriver, remove 8 or 10 screws depending on what model it is. lift the top case cover from the back about 1 inch and pull it forward to clear the cd tray. Be careful of the Reset/Eject button cable if the buttons are attached to the lid. If so, roll the lid Clockwise to upside down keeping the Ribbon cable from getting taught. Your in.... If you get in a bind, check out
Sep 23, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation 2 (PS2) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
