Question about Canon EOS 500D / Digital Rebel T1i Digital Camera
My Rebel T1i's built in flash stopped working after I used a 580EX external flash on it. It won't even show up on the LCD screen.
Really? the best solution available is to take the top of your camera off?
i don't think so.
Here's a very simple solution I found to get the flash to pop up without destroying your camera.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=31993875
the person suggests using a fingernail. (s)he must have long fingernails. I had to use a piece of paper folded in half. Swipe the paper from back to front, as in, from the eyepiece side towards the lens side.
Here's a picture: http://www.flickr.com/photos/dougpardee/133066175/
good luck
Posted on Dec 23, 2009
    Sergeant:
  • 246 Answers
There is a switch on the hot shoe, which detects if an external flash is attached. If the switch is obstructed by dirt, it won’t pop up after the external flash is removed. In this case, the internal flash won’t fire because the camera ‘thinks’ the external flash still on the hot shoe.
see more details on Build in flash not working
Posted on Sep 25, 2009
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 30 Answers
Hi, I have the Canon Rebel t1i (500d) and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether.
I then removed the four small screws being careful not to drop them and took off the mount for the external flash and then tried the flash it opened straight away. I then cleaned all the area of the mount and the two plates and replaced them all ensuring I fitted them exactly as before. I then checked the camera again and presto working fine. I hope this helps everyone with the problem.
Kevin (East Riding of Yorkshire)My Rebel T1i's built in flash stopped working - 1_15_2013_7_17_52_pm.jpg
Posted on Jan 15, 2013
I had the same problem on my T1i and used tweezers to lift up the two small metal strips covering the sensors. I turned the camera back on and took a test picture and my pop up flask came popping right up!
Posted on Dec 24, 2009
    New Friend:
Whenever I tried the pop up flash button the camera said "this function not available under these settings". I knew then it was a mecanical issue preventing the pop up flash being released. I used the solution suggested by "zavannie". I used an exacto blade and lifted the two metal springs which must push down once an external flash is inserted. By loosening them slightly the push down sensor gets released and then when you go to the menu settings and look at the flash settings, which would not even come up saying that external flash still attached, now becomes functional. As soon as I saw the flash settings started coming up I realized that the pop up flash would work, and when I pushed the button it worked. Brilliant zavannie.
Posted on May 21, 2013
Canon rebel T1i won't take a photo and gives message busy
Try formatting your card in your computer and then in the camera. If problem persists then try another memory card. You need to determine if it is a card or a camera problem
May 12, 2014 | Canon Cameras
Built in flash could not raised up
I have the Canon Rebel t1i (500d) and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this with the camera pointing away from me as if taking a picture. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether. (In picture 2 I show this plate removed and sitting in front of the mount only so you can see it removed, it was brought out backwards so towards me from the camera).
I hope this remedy works it did for me.
Jan 14, 2013 | Canon EOS 600D Rebel T3i Digital Camera
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
My rebel t1i eos 500 built in flash won't pop up
Hi, I have to Canon Rebel t1i and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether.
Kevin (East riding of Yorkshire)
Aug 12, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
Flash is not raising up..it shows in the lcd that the built-in flash could not be raised.turn the camera off and on again.i tried it many times but still the flash is not raising up.
Hi, I have the Canon Rebel t1i (500d) and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this with the camera pointing away from me as if taking a picture. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether. (In picture 2 I show this plate removed and sitting in front of the mount only so you can see it removed, it was brought out backwards so towards me from the camera).
Jun 16, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
LCD Display. I got the Rebel T1i but the LCD screen won't view anythign unless I press the display button. How can I have the LCD screen on while I am taking picture? Please advise..thanks
The T1i does not have this feature, like most digital SLR cameras. You should just look through the viewfinder to take the photo, which gives you a much more precise view of the photo, where you can better assess the correctness of focus, etc.
This feature is called "Live View" and is available on some newer or higher end models.
Mar 09, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
I cannot get my T1i to upload anymore. When I connect it to the computer the red button flashes for a second and then goes off. The computer does not show it is connected. The only thing different is that...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 14, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
Cannot use the screen to view on Canon Rebel T1i
I wish you know that you need to press LIVEVIEW button marked red Dot to enter live view mode.
Further more it will work in P,T,A,M modes and video camera modes only.Still it does not show live view the camera has a fault.
If this has solved it don't forget to rate me.
Dec 26, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon Digital Rebel XT Bulit-In Flash Strobes in Low Light
use more light:)
its very normal that it does that. it dosent get enough light so it cant focus. the only way it can autofocus is that it stobes the flash to adjust the focus automaticly. use an external flash like 580EX and u will get an focus asisten thru a red grid throne by the flash unit.
Nov 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 500D / Digital Rebel T1i Digital Camera Logo
2,689 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
