Question about Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier
The clean channel on my raven rg60 sounds a little distorted
My raven rg60 worked pretty good, had very good clean channel and everything until my ister moved back in and took the music room as a bed room so i couldnt play my guitar for about a month and a half and now all of a suden the clean channel sounds a bit fuzzy and my boss metal zone pedal has an awful problem with hardware (if you even ouch it when its turned on a very loud static sound occurs) please i need help on this one...i dont have the money for new equipment
2 Suggested Answers
  • 73 Answers
SOURCE: Intermittent shorts in a Crate Limo TX50DE Guitar
turn that ****** on and get a can of freeze spray. coming and going type issues is usually related to a failing electrolytic capacitor. there may also be a bad mosfet, rectifier, diode, etc. i would be suspect to caps. schematics probably only available thru crate and you have to pay a couple bucks, but trust me its worth the couple bucks spent and having it on its way than wasting hours online not getting anywhere. by the way i checked my sources and came up with nada.
yostamplifier.com
Posted on Jan 21, 2010
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Hi my sharp lcd tv when switch to DTV mode, the picture freezes however the sound still remains. I cannot change channels or go into any DTV menu options. Have you encountered this before?
It is probably not the TV , but coming from your signal source, cable box, or statile, and allot of times it is do to bad cabling, need to run new cable, RG60.
Jan 25, 2011 | Televison & Video
Hey, the clean channel on my Marshall 250dfx Combo amp isnt working the distortion and everything is working as normal, but the clean channel makes no sound at all, i was wondering if you can help?
The switching is done electronically by an analog gate chip. On IC9, check if the signal on pin 8 changes with switching between clean and OD... This is the actual signal that changes the gate. If you don't see a change there of say 5 volts, then the problem is in the circuits that drive this gate. If the signal is there, then the problem is in the clean channel audio op amps or the components around them. Let me know the results of the test.
Oct 18, 2010 | Marshall Amplification Marshall MG250DFX...
I have just purchased a tandberg 15.22 its in v good cond, no apparent head wear, I've replaced the belt (slow rewind) capstan is fine, there is distortion on the amp, I've cleane the record/amp/playback...
Resistors are good at causing distortion, you might spot one that has burned or broken. If the distortion is in both channels, which by what you say it is, then you might be looking for something common to both channels. Perhaps an IC.
Jan 21, 2010 | Audio Players & Recorders
My amp has 2 channels, clean and distortion. distortion works, but the clean channel doesnt. When i hit the button, it switches the distortion off, but there is no sound. The distortion light stays on...
initially you want to think bad solder joint, but it think its a bad mosfet or rectifier or diode. it would be hard for an untrained person to identify your problem let alone an experienced tech. it may be time to move on to another amp. in my shop it would be at least 65 bucks for the repair. so where did the "heat"/energy go from that point and what parts were affected. there may be a domino affect. burn one part, not usually.
yostamplifier.com
Jan 17, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Playback distortion
Good day sir, distortion can be caused by several factors, 1. overdriven audio source, try tuning down the volume to half. 2. the speakers are defective due to driver's coil scratching the magnet. need to replace the speakers, better swap first any good known speakers. hope this may help. if you may have any more questions, feel free to ask again. thanks
Jul 18, 2009 | EMC Zotac GF6100-C-E MCP61P GeForce 6100...
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Distorted sound when playing CD
have you tried cleaning the cd lens ?insert a lens cleaning cd , follow the voice instructions and your cd player will be as good as new.HAPPY LISTENING.
May 30, 2008 | Technics SL-PD687 5-Disc CD Changer
Distorted sound on all right channel inputs
yep but if your not a tech you should take this easy repair to a pro. Your problem is an open emitter resitor and happens when the units over driven or a speaker is bad for a while while it was working. if your a tech then check all of the emmitter resistors. also it could be a bad output device. Good Luck
May 27, 2006 | Yamaha RX-V496 Receiver
Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier Logo
187 people viewed this question
Top Crate Car Audio & Video Experts
xxxxxx xxx
Are you a Crate Car Audio and Video Expert? Answer questions, earn points and help others
