Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
How do you change the pull rope on a poulan 31cc gas trimmer
  • 279 Answers
You have to take the unit apart. Seperate the shaft from the engine. Then take the engine off the back side. This will allow access to the starter spool, where the rope goes. If you get that far, be careful when you wind the spring. Good luck...Lee
Posted on Sep 25, 2009
Weed eater featherlight XT260 rope pully
Your recoil could be messed up if you cant pull the rope out or if its just too hard to pull out you could have it too tight.
Jul 29, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Rope will not retract.
I am assuming you tried to pull start and the rope is stuck out. Just try pulling the rope while it is out, but stand on the hedge trimmer. Sometimes when this happens to me, I just pull the rope a little extra and then hang onto it when it goes back in. Alot of times, I think the rope gets caught on the outside of the retraction pulley causing a tangle.
Aug 05, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
Gas line with filter broke inside tank how to
get new line cut end at an angle , lube with oil and twist it in, snag the line and pull it out the filler hole and insert filter on the end, connect and enjoy.
May 28, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
I need to change the pull rope on my poulan pole saw 446t
Check out the video at the link I am providing and see if it is what you're looking for. Sure hope so and best wishes.
http://www.youtube.com/watch?v=Zs91D_wln2Q
Sep 01, 2009 | Poulan Garden
How do you change a poulan ploesaw pull cord
Use Clothes line rope and tie off at eye let and run rope as it was before and it will work fine. You can also make your new rope as long or short as you perfer.
Jul 29, 2009 | Poulan/Weed Eater No. 5000p 952711612 Pole...
Broken rop on weedeater gas trimmer
There is a spring under the starter spool, the one with the rope on it, leave the spring ALONE, Just take the spool and replace the rope as it is. You take the spool off, put the new rope on the spool, place the spool onto the spring and by holding one end of the rope straight up in one of the slots on the spool, go as many times as you can. When you have it as tight as it can go, hold your thumb down on the spool. Insert the rope through the hole available, grab the rope on the other side of the hole, (outside the casing). Hold the rope and S-L-O-W-L-Y allow the rope to retract. If it finishes before the rope runs out, pull on the rope and install the handle. If it tries to go beyond, hold the rope and install the handle there. Hope you have luck. Remember, leave the spring alone...Lee
Jul 23, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
325 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
