Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Thick black and grey line when scanning or copying a document.
When scanning or infact copying, the scanned image presents a black, sometimes black and grey band in the area where the paper lies next to the hinge of the door, or be it the area closer to the paper feeder. This happens in all modes of scanning ( auto, home or pro.), I've reinstalled the software, switched the machine off and then on, left it on, tried fiddling with the config settings, nothing. It's under warranty but it would be nice to know what's causing it.The problem must be with the scan bed, as it prints fotos or docs, loaded from the computer fine.
Thanks in advance.
Lse
    New Friend:
  • 170 Answers
Burn the thing it's junk. Go buy a commercial machine if you want something that works.
Posted on Apr 16, 2017
  • 26 Answers
SOURCE: Skipping lines
you should run a printer head cleanup and verify your cartrages are all full
Posted on Mar 08, 2008
Basti
  • 1447 Answers
SOURCE: Won't print but copies and scans
What operating system and is this on a network as a shared printer or wireless?
Download Epson net config from the website and run the program on all computer and configure it, make sure on the printer that ip is set to obtain automatically.
try this link as well
http://files.support.epson.com/htmldocs/cx11nf/cx11nfug/dwnh_7.htm
Posted on Apr 02, 2008
SOURCE: My All-in-One Printer
I need to download a driver for my printer epson stylus cx3810
Posted on Jun 16, 2008
  • 33 Answers
SOURCE: Epson Stylus Pro 4800 Never Before Seen Banding Problem
Is there any debris under the printhead nozzle plate?
Posted on Jul 01, 2008
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
Posted on Jun 16, 2009
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
BLACK MARK ON THE COPIES OR SCANNED IMAGE
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
Jan 17, 2014 | Sharp Mx-C402sc mx-C402sc
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
Thick black line on scanned document
Try to wipe the scanner glass clean with a soft lint free cloth.
If the "thick black line" also appears when making a copy, then there's something wrong with the scanner hardware. If this is the case, I highly recommend you to contact Lexmark Technical Support for additional assistance.
Oct 08, 2011 | Lexmark X4530 InkJet Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Thick Black line
This issue occurs if the scanner lamp is not getting enough voltage.
make sure that the printer isn't connected to a surge protector,
also you may try making a copy of any document.
this will be a hardware test, a reset of the printer might resolve the concern.
since the reset requires technical supervision,
revert back for further clarifications.
Ronald
HP AIO Support.
Jun 13, 2009 | Lexmark P3150 All-In-One InkJet Printer
Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Jan 05, 2007 | Canon DR-9080C Path-Through Scanner
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
105 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
