Question about DCS Island Hood
Ewave over range microwave
When the microwave is turned on it hums,The interior light does not go on and the turn table does not spin. Everything else on the microwave works - lights / fan ect.
  • 3 more comments
  • dogman816 Dec 24, 2007
    Thank you for the advice, but the microwave does not heat the food.
  • dogman816 Dec 25, 2007
    Thanks again, I just purchased a new machine, the fuses were fine
  • Anonymous Jan 14, 2009
    My Ewave is 5 years old and just started doing the same thing.
  • tricialbarbe Jan 24, 2009
    its doing the same thing
  • Anonymous Mar 20, 2014
    Has power because light works and motor has humming noise however does not spin the dual squirrel cage fans.
    Sergeant:
  • 288 Answers
I am assuming the food is heated. Most microwaves have only 2 major parts, the magnetron, the thing that makes the radio waves(heat) and the control module. The relays for the light and rotisserie are on the control module board. However, as the interior light does not work. have you tried a replacement? the table not spinning may be jammed with food or something keeping the motor from turning, that or it is seized up and needs replaced. I don't think the 2 things are related. Try a new bulb and then taking the bottom apart to gain asses to the motor that spins the plate before I looked at a new control board.
Posted on Dec 24, 2007
  • Rob Luna
    Rob Luna Dec 24, 2007
    Okay, that helps, you originally said everything else works light fan etc.. Remove the cover or front panel to expose the backside of the touch pad. this is the control module. On this and sometimes by the magnetron there are fuses. check them and if need to change them. If none are blown or this doesn't solve the problem, you may want to look into getting a new machine, as the replacement parts will cost about as much as a new micro. Hopefully this isn't a built in with a regular oven, then you may need to look for the repair part.
    P.S. be careful poking around inside the microwave. even if the cord is unplugged there are capacitors inside that can hold a serious charge and will shock the hell out off you if you touch them.
Ewave microwave
Over the range microwaves are generally the same as far as the rear dimensions but you will still need to install new mounting brackets and drill new holes in the cabinet. Each brand is slightly differnt in its mounting.
Nov 25, 2013 | Microwave Ovens
Shm1816s Samsung microwave oven wont shut off All lights off turn table not turning but you can hear the humming. the turn table plate gets very hot.
if the turntable is getting hot it means that the microwave is working but as the turntable is not turning , it means the adjustment of the door lock of your microwave may have become improper due to use.may be it got damaged.
call the technician of samsung microwave ,he will open the cabinet of microwave and make the adjustment of door lock proper.
Thanks
Nitin
Oct 19, 2013 | Microwave Ovens
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
Nov 06, 2012 | Microwave Ovens
EWave microwave oven KOT 131UW stopped working suddenly. Popped breaker. reset breaker. Microwave is still dead--no lights, no noises at all.
eWave microwave oven KOT 131UW stopped working suddenly. Popped breaker. reset breaker. Microwave is still dead--no lights, no noises at all.
Oct 23, 2010 | Kitchen Ranges
JVM2070SH001
you have a bad magnetron. go to sears parts direct and you can see the price for a new one. but it may not pay tp fix.
Feb 25, 2010 | GE Profile Spacemaker Over-the-Range...
E-Wave over the range microwave has blown main fuse
My Ewave has stopped heating eventho it appears to be running. Is is possible the power has been reduced or does the microwave need to be replaces
Nov 16, 2009 | Microwave Ovens
Runs but won't heat
Does the turn table and interior light come on?
Nov 25, 2008 | GE JVM1870 Microwave Oven
Turntable will not spin
This is usually a probem with a door switch or door switch mount or a problem on the control board. We repair these control panel assemblies for $39.95 nationwide.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 12, 2007 | Maytag MMC5000 Microwave Oven
Over range microwave not working properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 15, 2007 | Whirlpool MH6150XL Microwave Oven
DCS Island Hood Logo
776 people viewed this question
Top DCS Kitchen Ranges Experts
Carmen Mikulic
Sal De
Ismael Rodriguez...
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
