Question about Toshiba Televison & Video
I have a toshiba cx35d60 and the picture just randomly turned to a lighter color and has white lines all the way down the screen also when i shut the tv off i see a red blue and green light in the middle of the screen for a second and then they fade...i just had this tv fixed and on the second day home its giving me problems any thoughts?
    Genius:
  • Toshiba Master
  • 1,689 Answers
This type of fault is usually caused in the screen bias circuits, or in the blanking circuits. It is also possible to have this symptom from a short or a resistive leakage inside the electron gun of the picture tube.
A TV is a fairly complex device using many hundreds of various electronic components. As it ages from use and age its reliability will decrease. Especially with older sets, it is very possible that when you service the set there could be other faults shortly after.
Jerry G.
Posted on Sep 25, 2009
Color problem on Toshiba CRT TV
It sounds that the color mask inside the picture tube have been displaced due to hard shock. If so, it is irrepariable.
May 28, 2013 | iLO 2600 Television
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    I gotta a green screen
    It is possible that you have a shorted green CRT, you can remove the front speaker cover, and you will fine a focus block, and if you turn down the green screen voltage, very slowly, the green should turn down. if not then the gun (CRT) will have to be replace, If it does turn down, then go into the menu and turn the color are the way down and that should give you a black and white picture. If it is not black and white. adjust the red, blue, and green screen voltages until you receive a good black and white picture. Turn slowly they are touchy, and if turn to high, you will get retrace lines and the TV will shut down.
    Nov 14, 2010 | Toshiba 61A60 TV
    My Toshiba cinema series HD separates the red & blue color.
    The most likely cause is shorted convergence chips and possibly a few pico fuses.
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
    When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
    You can get a convergenece repair kit with instructions from the links below.
    Here are some of the most common problems with these sets...
    Problem #1) Convergence
    Yours may have one or more of the following symptoms...
    *Screen Looks 3-D
    *Colors wont align
    *Screen may look distorted or warped
    *No Audio/Video - TV Shuts down - May also make a constant chirping sound
    Problem #2
    Another common problem is dull or washed out video.
    Your set may have one or more of the following symptoms....
    *Dull looking picture
    *White looking picture
    *Halos around objects
    *Red/Orange looking picture
    You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
    I have blue arched lines on my sony kp 57wv600 is there a fix for this
    Those are retrace lines, the screen controls which are a technical control located under the front gray panel of your tv needs adjusted. This also could be an indication of a bigger problem, most common would be the focus block failing. it could also be of the picture tubes failing but this is not as common or possibly the crt driver ic's. There are specific diagnositc steps to preform to isolate the potental failure. this could lead to the tv going very bright then shutting down.
    The first thing a tech is going to do is to adjust the screens and leave, somtimes this is enough, but sometimes it is not. if you want to try and adjust the screen i have an instruction set below, but i must warn you that there are high voltages present when attempting this adjustment and can be dangerous if you are un familure with tv repair.
    Turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
    Aug 05, 2009 | Sony KP-57WV600 57" Rear Projection...
    Red picture toshiba model 50h71
    try to turn down the screen control and see how the tv reacts.
    Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
    I have a Toshiba DLP 62CM9UA
    hello everyone, I have been in this field for many years and if you have any problems about projector lamps or your projector ,pls just inform me and i will try my best to solve these problems. I am now still engaged in original projector lamp modules/ original bare lamp/ original lamp with housing/ replacement lamp/compatible bare lamp/main board/liquuid crystal chips/color wheel and other related accessories for the most popular projector brands... if u want to buy projector lamp ,welcome to contact with me. tks&best regards Grace MSN:myth_grace@hotmail.com skype:myth_grace email:grace@awolamps.com
    Dec 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
    Toshiba 42h81
    Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
    Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
    Dark picture (HELP)
    Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
    Dec 01, 2006 | Toshiba 32A42 32" TV
    Televison & Video Logo
    140 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
